查看: 1374|回复: 3
AR6700-V模拟SD-WAN测试
1、网络拓扑
实验拓扑很简单,1台AR作为RR,2台AR作为CPE,不涉及选路,最简单的1个路由域+1个传输端口,tunnel0作为创建BGP EVPN的控制通道,tunnel1作为数据通道。实验目的就是想抓包看下SD-WAN如何进行封装。
2、开启telnet
由于AR6700-V暂不支持telnet登录,不方便复制粘贴,开启命令如下
==========安装不安全的telnet模块
install feature-software WEAKEA
interface GE0/0/0
 ip address 10.100.1.1 255.255.255.0
aaa
 local-user admin password irreversible-cipher Admin@800
 local-user admin privilege level 3
 local-user admin service-type telnet
telnet server enable
telnet server-source all-interface
user-interface vty 0 4
 authentication-mode aaa
 idle-timeout 0 0
 protocol inbound telnet
3、实验配置
(1)HUB01兼做RR
sysname RR
route-policy test permit node 10
 apply extcommunity priority-color 10:2
ip vpn-instance vpn1
 vn-id 90
 ipv4-family
  route-distinguisher 9:2
  export route-policy test evpn
  vpn-target 111:1 export-extcommunity evpn
  vpn-target 111:1 import-extcommunity evpn
ipsec p2mp-policy sdwan
 esp encryption-algorithm aes-256-gcm
 esp authentication-algorithm sha2-256
interface GE0/0/1
 ip address 172.16.2.2 255.255.255.0
 ospf network-type p2p
 ospf enable 100 area 0.0.0.0
interface LoopBack0
 ip address 10.2.2.2 255.255.255.255
interface Tunnel0
 ip address 11.2.2.2 255.255.255.255
 tunnel-protocol sd-wan
 sd-wan service enable
interface Tunnel1
 ip binding vpn-instance vpn1
 ip address 12.2.2.2 255.255.255.255
 ipsec-p2mp-policy sdwan
bgp 100
 undo default ipv4-unicast
 private-4-byte-as enable
 peer 10.1.1.1 as-number 100
 peer 10.3.3.3 as-number 100
 group cpe internal
 ipv4-family vpn-instance vpn1
  import-route direct
  advertise l2vpn evpn
 l2vpn-family evpn
  undo policy vpn-target
  peer cpe enable
  peer cpe advertise encap-type sd-wan
  peer cpe reflect-client
  peer 10.1.1.1 group cpe
  y
  peer 10.3.3.3 group cpe
  y
 ipv4-family sd-wan
  peer cpe enable
  y
  y
ospf 100 router-id 10.1.1.1
 area 0.0.0.0
ip route-static 0.0.0.0 0.0.0.0 Tunnel0
ip route-static 10.1.1.1 255.255.255.255 color 1
ip route-static 10.3.3.3 255.255.255.255 color 3
evpn site 2 site-type rr
 system-id 10.2.2.2
 routing-domain 100 name mpls
 transport-network 10 name mpls
 transport-network-port 1
  routing-domain mpls
  transport-network mpls
  source-interface GE0/0/1
dtls server
 dtls server enable
 listening-port 55100
 listening-ip 172.16.2.2
(2)CPE01
sysname CPE1
 apply extcommunity priority-color 10:1
 vn-id 90
 ipv4-family
  route-distinguisher 9:1
interface GE0/0/1
 ip address 172.16.1.2 255.255.255.252
interface GE0/0/2
 ip address 192.168.1.1 255.255.255.0
interface LoopBack0
 ip address 10.1.1.1 255.255.255.255
interface Tunnel0
 ip address 11.1.1.1 255.255.255.255
interface Tunnel1
 ip address 12.1.1.1 255.255.255.255
bgp 100
 peer 10.2.2.2 as-number 100
 peer 10.2.2.2 connect-interface LoopBack0
  import-route direct
 l2vpn-family evpn
  peer 10.2.2.2 enable
  y
  peer 10.2.2.2 advertise encap-type sd-wan
 ipv4-family sd-wan
  y
 area 0.0.0.0
ip route-static 10.2.2.2 255.255.255.255 color 2
evpn site 1 site-type cpe
 system-id 10.1.1.1
  routing-domain mpls
dtls client
 peer system-id 10.2.2.2 ip 172.16.2.2 port 55100
(3)CPE02
sysname CPE2
 apply extcommunity priority-color 10:3
 vn-id 90
 ipv4-family
  route-distinguisher 9:3
interface GE0/0/1
 ip address 172.16.3.2 255.255.255.0
interface GE0/0/2
 ip address 192.168.3.1 255.255.255.0
interface LoopBack0
 ip address 10.3.3.3 255.255.255.255
interface Tunnel0
 ip address 11.3.3.3 255.255.255.255
interface Tunnel1
 ip address 12.3.3.3 255.255.255.255
bgp 100
  import-route direct
 l2vpn-family evpn
  y
 ipv4-family sd-wan
  y
(4)Core-SW01
sysname Core-SW1
ospf 100 router-id 0.0.0.1
 area 0.0.0.0
interface GE1/0/1
 undo portswitch
 undo shutdown
 ip address 172.16.1.1 255.255.255.252
interface GE1/0/2
 undo portswitch
 undo shutdown
 ip address 172.16.2.1 255.255.255.252
interface GE1/0/3
 undo portswitch
 undo shutdown
 ip address 172.16.3.1 255.255.255.252
4、激活临时license
AR6700-V的数据转发有约束,需要进行激活,否则路由转发会异常,3台都需要配置
license trial enable
5、实验结果
(1)检查bgp evpn邻居和bgp sd-wan邻居,前者负载业务路由传递和数据隧道建立,后者负责BGP EVPN控制通道和隧道TNP封装信息分发。
(2)查看SD-WAN数据通道
(3)PC01 ping 测PC02 测试,可以通,并在CPE01的G0/0/1口进行抓包,遗憾的是数据包封装错误,无法看到完整数据包。这里做了点小调整,将加密模板去掉,避免被IPSec加密导致无法看到具体数据包,在CPE01和CPE02上执行即可。
interface Tunnel1
 undo ipsec-p2mp-policy
发表于 2026-1-7 13:15:56 | 显示全部楼层
[i=s] 本帖最后由 ccjjzj 于 2026-1-7 13:22 编辑 [/i]
vAC是h3c的虚拟ac控制器么,怎么作为管理交换机的 要做那些配置
 楼主| 发表于 2026-1-7 13:36:44 | 显示全部楼层
不是,这里的VAC只是作为AR的telnet客户端
发表于 2026-1-8 10:37:11 | 显示全部楼层
[i=s] 本帖最后由 slch 于 2026-1-8 10:39 编辑 [/i]
AR6700-V有高级版SRv6授权么,什么时候做一个SRv6的实验。
