查看: 1374|回复: 3
锐捷SW对接Agile Controller不成功~~
[i=s] 本帖最后由 cfplzjc 于 2025-7-20 09:50 编辑 [/i]
1、网络拓扑
Ruijie-SW1作为核心交换机,agg1上联Ruijie-RSR,g0/0旁挂华为AR充当DHCP服务器,g0/3横联华为Agile Controller充当radius服务器,做一个小小的portal实验
目前进展:输入1.1.1.1无法跳转portal页面,ISP为家用路由器,通过在Ruijie-RSR和家用路由器做2次NAT,实现访问外网。
2、网络配置
(1)Ruijie-RSR
hostname ISP01
ip access-list standard 10
 1 permit 192.168.1.0 0.0.0.255
interface GigabitEthernet 0/0
 ip address dhcp
 ip nat outside
interface AggregatePort 1
 no switchport
 ip address 172.16.1.1 255.255.255.252
 ip nat inside
interface GigabitEthernet 0/1
 port-group 1
interface GigabitEthernet 0/2
 port-group 1
ip nat inside source list 10 interface GigabitEthernet 0/0 overload
ip route 192.168.1.0 255.255.255.0 172.16.1.2
(2)Ruijie-SW01
hostname HX-SW01
http redirect direct-site 10.1.5.107
http redirect direct-site 10.168.1.254
service dhcp
radius-server host 10.1.5.107 key pass@800
aaa group server radius huawei
 server 10.1.5.107
aaa new-model
aaa accounting network huawei start-stop group huawei
aaa authentication web-auth huawei group huawei
web-auth template huawei v2
 ip 10.1.5.107
 url http://10.1.5.107:8080/portal
 fmt cmcc-normal
 authentication huawei
 accounting huawei
web-auth portal key pass@800
vlan range 1,10
 no switchport
 ip address 172.16.2.2 255.255.255.252
 no switchport
 ip address 172.16.1.2 255.255.255.252
 no switchport
 port-group 1
 no switchport
 port-group 1
interface GigabitEthernet 0/3
 no switchport
 ip address 10.1.5.254 255.255.255.0
interface GigabitEthernet 0/4
 switchport mode trunk
 web-auth enable huawei
interface VLAN 10
 ip address 192.168.1.254 255.255.255.0
 ip helper-address 172.16.2.1
ip route 0.0.0.0 0.0.0.0 172.16.1.1
(3)DHCP_Server
 sysname dhcp
dhcp enable
ip pool user
 gateway-list 192.168.1.254
 network 192.168.1.0 mask 255.255.255.0
 dns-list 10.168.1.254
interface GigabitEthernet0/0/0
 ip address 172.16.2.1 255.255.255.252
 dhcp select global
ip route-static 192.168.1.0 255.255.255.0 172.16.2.2
(4)Ruijie-SW2
hostname Access-SW02
vlan range 1,10
 switchport access vlan 10
(5)radius配置
=======================设备管理
=======================添加用户
========================认证授权,略,其它实验已多次贴出
3、实验结果
(1)radius server和web-server状态正常
(2)直接输入portal认证地址,也认证不成功,radius无认证记录
(4)参考案例链接,唯一的区别这里的是有线web认证
https://www.doc88.com/p-90287694901320.html
发表于 2025-7-12 18:08:17 | 显示全部楼层
lol 大佬,Agile Controller能分享下不
 楼主| 发表于 2025-7-18 19:50:07 | 显示全部楼层
添加了snmp参数,还是不行,放弃了。。。
发表于 2025-7-29 12:49:35 | 显示全部楼层
Agile Controller镜像放出来大家一起研究一下
