查看: 13777|回复: 15
关于qemu镜像无法正常启动的问题
我这里有个问题想请教一下,关于qemu的镜像,凡是涉及到vios,nxosv9k,nxosv7k以及arista 的veos等(),设备都无法正常启动,设备启动的过程中,各种报错信息。比如N7K的报错:
Unknown boot option `ide_generic.probe_mask=0x0': ignoring
BUG: spinlock spinlock held for long time on CPU#0, swapper/1
lock: ffffffff8074ff00, .magic: dead4ead, .owner: swapper/1, .owner_cpu: 0
vios的报错信息如下:
error: Can't get controller info..
Booted IOSv. Boot args: [/vios_l2-adventerprisek9-m]
Smart Init is enabled
然后就没有然后了,设备启动卡住,不停报错,请问版主能否解答一下,非常感谢。
另:社区版2.0.3-92,以及专业版-2.0.4-20都试过了,都是同样的错误。
发表于 2019-6-18 11:27:51 | 显示全部楼层
镜像目录检查过了吗 有没有重复 镜像名是否满足规则
 楼主| 发表于 2019-6-18 11:46:57 | 显示全部楼层
谢谢版主的快速回复,目录的命名规则和qemu的名称规则都是按照官方文档来的。如下:
root@eve-ng:/opt/unetlab/addons/qemu# ls
nxosv9k-7.0.3.I5.2  titanium-nxosv7.3.0.1  vios-15.5.3M
root@eve-ng:/opt/unetlab/addons/qemu# ls titanium-nxosv7.3.0.1
hda.qcow2
root@eve-ng:/opt/unetlab/addons/qemu# ls vios-15.5.3M
virtioa.qcow2
root@eve-ng:/opt/unetlab/addons/qemu# ls nxosv9k-7.0.3.I5.2
hda.qcow2
都是带v版本的qemu版本不能运行,比如ASA8.42能正常启动,但是ASAV-981就不能正常启动。
 楼主| 发表于 2019-6-18 11:54:00 | 显示全部楼层
hda.qcow2
virtioa.qcow2
hda.qcow2
 楼主| 发表于 2019-6-18 12:48:01 | 显示全部楼层
   以下是刚刚加载IOSv的报错信息:
                      GNU GRUB  version 2.00
|IOSv        |
      Use the ^ and v keys to select which entry is highlighted.
      Press enter to boot the selected OS, `e' to edit the commands
      before booting or `c' for a command-line. ESC to return
      previous menu.
Booted IOSv. Boot args: [/vios-adventerprisek9-m]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, IOSv Software (VIOS-ADVENTERPRISEK9-M), Version 15.6(2)T, RELEASE SOFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Tue 22-Mar-16 16:19 by prod_rel_team
-Traceback= 114F778z 130845z 15E43Ez 15E160z 15DF6Dz 158095z 158CCBz 158C5Fz 3A7FEF8z 3A83DE5z 3A83D0Fz 3A83CE9z 3A83C81z 3D187A0z - Process "Chunk Manager", CPU hog, PC 0x00153DA5
-Traceback= 114F778z 130845z 15E43Ez 15E160z 15DF6Dz 158095z 158CCBz 158C5Fz 3A8569Ez 3D187C8z - Process "Chunk Manager", CPU hog, PC 0x00153D9D
-Traceback= 114F778z 130845z 15E43Ez 15E160z 15DF6Dz 158095z 158CCBz 158C5Fz 3A7FEF8z 3A83205z 3A832A3z 3A8317Fz 3A83020z 105EB6Bz 26420Bz - Process "Load Meter", CPU hog, PC 0x00153D9D
-Traceback= 114F778z 130845z 15E43Ez 15E160z 15DF6Dz 158095z 158CCBz 158C5Fz 3A7FEF8z 3A83DE5z 3A83D0Fz 3A83CE9z 3A84D0Cz 105EB84z 26420Bz - Process "Load Meter", CPU hog, PC 0x00153D9D
-Traceback= 114F778z 130845z 15E43Ez 15E160z 15DF6Dz 158095z 158CCBz 158C5Fz 3A7FEF8z 3A83DE5z 3A83D0Fz 3A83CE9z 3A84D0Cz 105EB84z 26420Bz - Process "Load Meter", CPU hog, PC 0x00153DA5
发表于 2019-6-18 12:55:09 | 显示全部楼层
linux命令行下执行kvm-ok检查下
 楼主| 发表于 2019-6-18 12:57:27 | 显示全部楼层
root@eve-ng:~# kvm-ok
INFO: /dev/kvm exists
KVM acceleration can be used
 楼主| 发表于 2019-6-18 12:59:15 | 显示全部楼层
root@eve-ng:~# df -h
Filesystem                    Size  Used Avail Use% Mounted on
udev                          3.9G     0  3.9G   0% /dev
tmpfs                         799M   14M  785M   2% /run
/dev/mapper/eve--ng--vg-root   31G  4.2G   26G  15% /
tmpfs                         3.9G     0  3.9G   0% /dev/shm
tmpfs                         5.0M     0  5.0M   0% /run/lock
root@eve-ng:~# free -m
              total        used        free      shared  buff/cache   available
Mem:           7981         395        7136          24         449        7282
Swap:          8191           0        8191
root@eve-ng:~# top
top - 07:58:02 up 48 min,  2 users,  load average: 0.00, 0.13, 0.23
Tasks: 209 total,   1 running, 208 sleeping,   0 stopped,   0 zombie
%Cpu0  :  0.0 us,  0.3 sy,  0.0 ni, 99.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
%Cpu1  :  0.3 us,  0.3 sy,  0.0 ni, 99.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
%Cpu2  :  0.0 us,  0.3 sy,  0.0 ni, 99.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
%Cpu3  :  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
KiB Mem :  8173460 total,  7307260 free,   405824 used,   460376 buff/cache
KiB Swap:  8388604 total,  8388604 free,        0 used.  7456896 avail Mem
tmpfs                         3.9G     0  3.9G   0% /sys/fs/cgroup
/dev/sda1                     472M   83M  365M  19% /boot
 楼主| 发表于 2019-6-18 13:03:29 | 显示全部楼层
root@eve-ng:~# dpkg -l eve-ng
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                 Version         Architecture    Description
ii  eve-ng               2.0.3-92        amd64           A new generation software for networking labs
发表于 2019-6-18 13:20:45 | 显示全部楼层
| Status=Not/Inst/Conf-fil ...
重新下载qemu镜像或者测试win7镜像是否正常 目前还没遇到过你这个情况
