查看: 11233|回复: 25
CCIE Security v5 Lab-EVE-NG Config Topology(UNL) with Startup Configurations
Basic Instructions:
  • Start up configurations included for all the devices which come pre-configured in real lab exam.
  • Topology is using 4 physical interfaces of EVE-NG Server (Bare Metal) bound to Cloud Interfaces for interconnecting nodes but these cloud interfaces can be updated based on user EVE-NG environment setup.  Tip: If you  know EVE-NG good enough, this all can be managed even with 2 Interfaces.
  • Topology is connecting to Physical Switch through one of the physical interfaces on EVE-NG server which can also be updated to use only virtual switches (vIOS,IOL) as they can provide all the features required (atleast as far as Lab Dumps are concerned) minus physical IP Phone (Voice VLAN limitation on virtual Switches) + Access Point (for obvious reason).
  • To represent servers (loopbacks on routers), I used text based images which are just cosmetic stuff and can be removed (too lazy to update those
  • Most Importantly: Just use your head!
原链接:
https://certcollection.org/forums/topic/330220-ccie-security-v5-lab-eve-ng-config-topologyunl-with-startup-configurations/?tab=comments#comment-1326708
CCIE_Securityv5_EVE-NG_Lab_UNL_with_Startup_Configs-Mr_Robot.zip
1.03 MB, 下载次数: 411
售价: 1 EML币  [记录]
发表于 2020-4-23 18:35:50 | 显示全部楼层
活捉小蜜蜂。我竟然是第一个,哈哈哈
12万
发表于 2020-4-23 20:07:22 | 显示全部楼层
感謝版主分享
16万
发表于 2020-6-19 10:18:13 | 显示全部楼层
谢谢分享!!!
发表于 2020-7-5 19:50:57 | 显示全部楼层
这个拓扑牛逼的   机器带不动。。。
发表于 2020-7-20 01:02:44 | 显示全部楼层
赞,牛皮大佬
发表于 2020-7-21 14:23:47 | 显示全部楼层
感谢分享   机器带不动
发表于 2020-7-21 14:59:20 | 显示全部楼层
大佬 给力  经常分享高端
发表于 2020-7-21 15:02:38 | 显示全部楼层
期待CCIE EI也能模拟出差不多的环境 方便自己多操作配置
发表于 2020-8-24 17:34:40 | 显示全部楼层
