查看: 7540|回复: 10
Viptela SD-WAN with cEdges by UD
Viptela SD-WAN lab with cEdges
LAB is create on EVE-PRO !!! If you will import it in the EVE Communty the all hosts dockers will disappear from lab!
Lab hs uploaded custom 3D topology, it is interactive. After you have started nodes, you can open 3D topology and use it for labbing. nodes are active on click for consoles.
In the lab were used:
Viptela 18.4.4 images
vManage, vBond, vSmart and vEdge 18.4.4
IOL SW i86bi_LinuxL2-AdvEnterpriseK9-M_152_May_2018.bin
CSRv1000 csr1000vng-universalk9.16.06.07.Everest
CSRv1000 SD-WAN csr1000vng-ucmk9.16.12.1e-sdwan
ASA 9.1.5 with multiconexts
EVE-PRO Docker station Server-gui as management station and for hosts.
how to operate with Viptela licensing you will find in my friend's blog, or use your own sd-wan licenses.
https://pocvlab.com/cisco-sd-wan-vedges ... nboarding/
enjoy
Uldis
sd-wan-cedge-ud.zip
974.04 KB, 下载次数: 98
售价: 10 EML币  [记录]
发表于 2020-2-12 10:04:14 | 显示全部楼层
谢谢小蜜蜂的分享。
发表于 2020-2-12 10:33:07 | 显示全部楼层
看来需要升级一下pro版本才行了
发表于 2020-2-12 10:34:49 | 显示全部楼层
感谢,看看去
发表于 2020-2-12 11:07:40 | 显示全部楼层
社区版本不行
发表于 2020-2-12 12:30:55 | 显示全部楼层
非常感谢,虽然是pro版本。。。
发表于 2020-4-22 09:54:33 | 显示全部楼层
感谢分享!
发表于 2021-2-26 14:15:05 | 显示全部楼层
没有cookbook?
发表于 2021-10-22 09:34:49 | 显示全部楼层
发表于 2021-10-22 11:44:25 | 显示全部楼层
破解许可那个还有效么
