查看: 18478|回复: 20
6.EVE官方支持镜像列表
EVE-NG 支持镜像
Dynamips (Cisco IOS emulation)
  • c7200-adventerprisek9-mz.152-4.S6 (supported cards: PA-FE-TX, PA-4E, PA-8E)
  • c3725-adventerprisek9-mz.124-15.T14 (supported cards: NM-1FE-TX, NM-16ESW)
  • c1710-bk9no3r2sy-mz.124-23
  • Other images from the  series above should work too
IOL (IOS on Linux )
  • L2-ADVENTERPRISE-M-15.1-20131216.bin
  • L2-ADVENTERPRISE-M-15.1-20140814.bin
  • L2-IPBASEK9-M-15.1-20130726.bin
  • L3-ADVENTERPRISEK9-M-15.4-1T.bin
  • L3-ADVENTERPRISEK9-M-15.4-2T.bin
  • L3-ADVIPSERVICES-M-15.1-2.9S.bin
  • And all newer version
Qemu镜像
  • Cisco ACS 5.6, 5.8
  • Cisco AMP Private cloud
  • Cisco ISE 1.2, 1.4
  • Cisco ISE 2.1, 2.2, 2.3, 2.4, 2.6
  • Cisco ASA 8.0.2 (Single and Multi Context)
  • Cisco ASA 8.4 Multicontext Support
  • Cisco ASA 9.1.5 Multicontext Support
  • Cisco ASAv 9.6.2, 9.7.1 or later
  • Cisco DCNM 11.x
  • Cisco IPS 7.1
  • Cisco Firepower 6.x  Management centre (FMC)
  • Cisco Firepower 6.x Threat defence ASAv (FTD)
  • Cisco Firepower 6.x NGIPSv
  • Cisco Firepower 5.4 (NGIPS, FMC)
  • Cisco CSR 3.16, 3,17
  • Cisco CSR 16.x (Everest, Fuji, etc)
  • Cisco CSR SD-WAN 16.x
  • Cisco vIOS L3
  • Cisco vIOS L2
  • Cisco ESA 9.7, 9.8, 10.x, 11.x Email Security Appliance
  • Cisco WSA 8.6, 9.2 10.x, 11.x Web Security Appliance
  • Cisco CDA 1.0 Context Delivery Agent
  • Cisco NXOS Titanium 7.1.0.3
  • Cisco NXOSk9 (require source of 2xCPU and 8G RAM for single node)
  • Cisco Prime Infra 3.x
  • Cisco StealthWatch 7.x
  • Cisco XRv 5.2.2, 5.3.2, 6.0.1, 6.0.2
  • Cisco XRvK9 6.x.x (require source of 4xCPU and 16G RAM for single node)
  • Cisco vWLC, 7.4. 8.0.100, 8.2.x, 8.3.x, 8.6
  • Cisco vNAM Virtual Network Analysis Module 6.2.x
  • Cisco vWAAS 200.5.5, 6.2.3
  • Cisco Viptela SD-WAN 18.x, 19.x
  • Cisco CUCM 11.5.1.11900-26, 12.x
  • Juniper vSRX 12.1.47D
  • Juniper Olive M series
  • Juniper vSRX NG 15.1×49-D40.6, D70, D100, D110
  • Juniper vSRX NG 17.x, 18.x, 19.x, 3.0
  • Juniper vMX 14.1.4R10
  • Juniper vMX 16.1R3.10, 17.x, 18.x, 19.x  VCP (control plane node)
  • Juniper vMX 16.1R3.10, 17.x, 18.x, 19.x VFP (forwarding plane node)
  • Juniper vMX 17.1, 17.2, 17.3, 18.x, 19.x VCP (control plane node)
  • Juniper vMX 17.1, 17.2, 17.3, 18.x, 19.x VFP (forwarding plane node)
  • Juniper vQFX 10K VRE 15.1X53, 17.x, 18.x (routing engine)
  • Juniper vQFX 10K VFE 15.1X53, 17.x, 19.x (forwarding engine)
  • Juniper VRR 18.x, 19.x
  • Junos J-Space 16.1
  • Alcatel 7750SR: 13.0.R3
  • A10, vThunder 2.7.1, 4.x
  • Apple OSX ( https://github.com/kholia/OSX-KVM )
  • Aruba: Clearpass 6.x
  • Aruba Virtual Mobility Controller 8.x
  • Arista vEOS 4,17.2F and later versions
  • Barracuda NGFW
  • Brocade vADX 3.01.1
  • Checkpoint FW: R77-20, R77-30, R80-x
  • Citrix Netscaler 11.0.62
  • Dell SonicWall 11.3.0
  • CumulusVX 2.5.3, 3.6, 3.7
  • Cyberoam FW
  • ExtremeOS 21.1.14
  • F5 BIG-IP 12.x, 13.x, 14.x, 15.x
  • F5 BIG-IQ 6.x
  • Fortinet Manager v5.x, v6.x
  • Fortinet Mail 5.3, 5.4
  • Fortinet FGT v5.x, 6.x
  • Fortinet 5.2.3, 5.6, 6.x
  • Huawei USG6000v
  • Huawei Ar1000v Router
  • HP VSR 1000 7.x
  • Infoblox 8.x
  • Mikrotik 6.30.2, 6.40
  • PaloAlto FW 7.0, 7.1, 8.x, 9.x
  • PaloAlto Panorama 8.x, 9.x
  • Pulse Secure
  • pfSense FW 2.3, 2.4
  • Radware Alteon
  • Riverbed VCX 9.x
  • Silver Peak SD-WAN 8.x
  • SonicWALL FW NSv 200.x
  • Sophos  XG Firewall, SG UTM
  • S-Terra FW, Gate 4.1,
  • S-Terra CSP-VPN gate 3.1
  • TrendMicro FW VTPS 5.x
  • Versa Networks SD-WAN 16.x
  • VMWare ESXi 6.5, 6.7
  • VMWare vCenter 6.5, 6.7
  • VMWare NSX 6.4
  • VMware SD-WAN Velocloud 3.x
  • VyOS 1.1.6
  • Windows 7
  • Windows 8.1
  • Windows 10
  • Windows Server 2003
  • Windows Server 2008R2
  • Windows Server 2012 R2
  • Windows Server 2016
  • Windows Server 2019
  • Linux TinyCore
  • Linux Slax
  • Linux Mint
  • Linux Kali x64 Full
  • Linux Kali x386 light
  • Linux Ubuntu Desktop 16.04, 18.x
  • Linux DSL 4.4.10
  • Linus Ubuntu Server 16.04, 18.x Webmin
  • Linux NETem: NETem bandwidth limitation, delay, jitter and packet loss.
  • Ostinato traffic generator 0.7, 0.8, 9.0
发表于 2020-4-22 00:05:39 | 显示全部楼层
去哪下载 Huawei Ar1000v Router 求链接谢谢
 楼主| 发表于 2020-4-22 00:07:54 | 显示全部楼层
论坛搜索ar1000v
发表于 2020-4-22 00:19:11 | 显示全部楼层
求网盘链接谢谢
发表于 2021-1-15 22:00:56 | 显示全部楼层
发表于 2021-6-25 10:29:22 | 显示全部楼层
asa地址谢谢谢谢谢谢
发表于 2021-6-25 10:30:10 | 显示全部楼层
求网盘,我需要ASA的镜像,谢谢
4万
发表于 2022-3-16 03:15:39 | 显示全部楼层
这个列表不错,官方支持需要了解
发表于 2022-4-5 15:39:38 | 显示全部楼层
很需要cisco vios的镜像
发表于 2022-7-8 15:28:35 | 显示全部楼层
asdfasd asdfasdfasdfasdf
