查看: 88913|回复: 252
【奖励】EVE-NG镜像模板资源占用统计
回帖奖励 22950 EML币 回复本帖可获得 50 EML币奖励! 每人限 2 次
EVE  Image folderVendor image nameCPU virtual cores Single nodeRAM MB Single nodeNumber of Nodes Change valueRAM MB TotalCPU virtual cores total
Total  RAM and CPU usage   00
a10A10 vThunder12048000
acsCisco ACS24096000
asaCisco ASA 8.4.2, 9.1.512048000
asaCisco ASA 8.0.21256000
asavCisco ASAv12048100
alteonRadware Alteon26144000
ampcloudCisco AMP Private Cloud48192000
apicemCisco APIC-EM632768000
arubaAruba VMC34096000
arubacxAruba CX Switch24096000
barracudaBarracuda NGFW22048000
bigipF5 BIG IP48192100
bigipF5 BIG IQ MGMT416384000
brocadevadxBrocade vADX Switch22048000
c1710Cisco Dynamips 1710196000
c3725Cisco Dynamips 37251256000
c7200Cisco Dynamips 72001512000
cdaCisco Context Delivery Agent22048000
cipsCisco IPS 425512048000
clearpassAruba ClearPass26144000
coeusCisco WSA14096000
cpsgCheckpoint 80-3048192000
csr1000vCisco CSRv1000 3.X13072000
csr1000vngCisco CSRv1000 16.X14096000
csr1000vngCisco CSRv1000 SD-WAN14096000
cucmCisco CUCM 11, 1224096000
cumulusCumulus VX1256000
cyberoamCyberoam FW11024000
dcnmCisco DCNM28192000
dockerEVE Docker station any11024000
esxiVM Ware ESXi24096000
extremexosExtreme XOS12048000
firepower6Cisco Firepower FMC48192000
firepower6Cisco Firepower FTD48192000
firepower6Cisco Firepower NGIPS48192000
firepowerSourcefire Def Center44096000
firepowerSourcefire NGIPS44096000
fortinetFortinet FGT11024000
fortinetFortinet FAZ12048000
fortinetFortinet FMG14096000
hpvsrHP VSR100024096000
huaweiar1kHuawei AR 100012048000
huaweiusg6kvHuawei USG 600024096000
infobloxInfoblox DDI12048000
IOLCisco IOL node0.11024000
iseCisco ISE48192000
jspaceJuniper J-Space28192000
junipervrrJuniper VRR12048000
linuxLinux host12048000
mikrotikMkrotik router1256000
nsvpxCitrix Netscaler NSVPX22048000
nsxVM Ware NSX416384000
nxosv9kCisco Nexus 9000v28192000
oliveJuniper generic J Router14096000
ostinatoOstinato traffic generator1512000
osxMAC OSX node43072000
paloaltoPalo Alto FW28192000
paloaltoPalo Alto Panorama48192000
pfsensepfSense FW12048000
phoebeCisco ESA14096000
primeCisco Prime Infra412288000
pulsePulse Secure12048000
riverbedRiverbed VCX12048000
silveredgeSilver Peak EdgeConnect24096000
silverorchSilver Peak Orchestrator44096000
sonicwallSonicWALL FW48192000
sophosutmSophos UTM FW24096000
sophosxgSophos XG FW12048000
sourcefireSourceFire node44096000
stealthCisco Stealth Watch SMC38192000
stealthCisco Stealth Watch SFC38192000
sterraS-Terra FW12048000
timoscpmNokia 7750SR CPM12048000
timosiomNokia 7750SR IOM LC12048000
timosAlcatel/Nokia 7750 old12048000
titaniumCisco NX7K Titanium14096000
trendmivtpsTrendMicro vTPS FW28192000
ucspeCisco UCS Platform Emulator12048000
vcenterVM Ware vCenter210240000
veloedgeVM Ware Velocloud Edge24096000
velogwVM Ware Velocloud Gateway48192000
veloeorchVM Ware Velocloud Orchestrator416384000
veosArista vEOS Switch12048000
versaanaVersa Networks Analytics24096000
versadirVersa Networks Director24096000
versafvnfVersa Networks FlexVNF24096000
viosCisco vIOS Router11024000
viosl2Cisco vIOS Switch11024000
vmxJuniper VMX 1412048000
vmxvcpJuniper VMX VCP12048000
vmxvfpJuniper VMX VCE34096000
vnamCisco Virtual Network Analysis Module24096000
vqfxpfeJuniper vQFX PFE24096000
vqfxreJuniper vQFX RE22048000
vsrxJuniper vSRX 1424096000
vsrxngJuniper vSRX 18, 1924096000
vtbondCisco Viptela vBond22048000
vtedgeCisco Viptela vEdge22048000
vtmgmtCisco Viptela vManager416384000
vtsmartCisco Viptela vSmart22048000
vwaasCisco WAAS12048000
vwlcCisco vWLC (Wireless Controller)12048000
vyosVyOS router1512000
winWindows workstation14096000
winserverWindos Server18192000
xrv9kCisco XRv9000416384000
xrvCisco XRv13072000
EVE-CALC2.0.xlsx
16.1 KB, 下载次数: 193
发表于 2019-12-14 06:57:25 | 显示全部楼层
回帖奖励 +50 EML币
厉害v5不错
发表于 2019-12-17 03:02:10 | 显示全部楼层
回帖奖励 +50 EML币
看这个列表 eve-ng 真的牛逼
发表于 2019-12-18 08:26:15 | 显示全部楼层
回帖奖励 +50 EML币
支持版主
发表于 2019-12-18 08:28:27 | 显示全部楼层
回帖奖励 +50 EML币
eve-ng是真的不错,就是要求配置要高一点才行
发表于 2019-12-19 10:56:59 | 显示全部楼层
回帖奖励 +50 EML币
太好了,可以参考下。
发表于 2019-12-19 15:40:54 | 显示全部楼层
回帖奖励 +50 EML币
感谢版主
发表于 2019-12-19 15:41:14 | 显示全部楼层
回帖奖励 +50 EML币
感谢版主
发表于 2019-12-20 11:44:03 | 显示全部楼层
回帖奖励 +50 EML币
厉害了666666
发表于 2019-12-25 14:29:19 | 显示全部楼层
回帖奖励 +50 EML币
这个功能太恐怖了···
