查看: 608|回复: 2
华三最新的VSR1000路由器能否在EVE-NG模拟器上实现SRv6 TE引流
使用华三最新版本Release 1362P38+高级授权函,在EVE-NG模拟器上能不能实现SRv6TE呢,BE是正常的,但是TE的实例路由一直无法引入隧道
<SR2>display license client
Username: admin
Ciphertext password: ******
License server's IPv4 address: 192.168.225.200, port: 5555
License client: Enabled
License Count: 1
License Name: VSR1000_ADVANCE
License Description: H3C VSR1000 License(Cowmare V7,Advanced Features,Permanent)
Current State: In use
Get Time: 2026-06-13 23:31:
设备配置.rar
4.51 KB, 下载次数: 22
发表于 2026-6-23 23:46:53 | 显示全部楼层
什么方案呢,看到对应路由的拓展属性是否存在color值呢
发表于 2026-6-29 12:45:19 | 显示全部楼层
color 都传递正常,但是就是流量不走te. 路由表项都有。
配置::
 bgp routing-table ipv4 unicast vpn-instance a 10.0.0.16
 BGP local router ID: 10.0.0.11
 Local AS number: 100
 Paths:   1 available, 1 best
 BGP routing table information of 10.0.0.16/32:
 RR-client route.
 Rely nexthop    : FE80::5203:FF:FE0D:2
 Original nexthop: 2401::12
 OutLabel        : 3
 Ext-Community   : <RT: 100:1>, <CO-Flag:Color(00:1000)>
 PrefixSID       : End.DT4 SID <2401:2:1000:C:0:1:0:6>
 AS-path         : 300
 Origin          : incomplete
 Attribute value : MED 0, localpref 100, pref-val 0
 State           : valid, internal, best
 Originator      : 10.0.0.12
 Cluster list    : 10.0.0.9
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 VPN-Peer UserID : N/A
 DSCP            : N/A
 EXP             : N/A
 Tunnel policy   : NULL
 Rely tunnel IDs : N/A
dis segment-routing ipv6  forwarding
Total SRv6 forwarding entries: 3
Flags: T - Forwarded through a tunnel
       N - Forwarded through the outgoing interface to the nexthop IP address
       A - Active forwarding information
       B - Backup forwarding information
ID            FWD-Type      Flags   Forwarding info
2148532226    SRv6PSIDList  NA      GE2/0
                                    FE80::5203:FF:FE0A:1
                                    {2401::10, 2401::12}
2149580801    SRv6PCPath    TA      2148532226
2150629377    SRv6Policy    TA      2149580801
dis segment-routing ipv6 te  policy up
Name/ID: c-a/0
 Color: 1000
 End-point: 2401::12
 Name from BGP:
 BSID:
  Mode: Dynamic             Type: Type_2              Request state: Succeeded
  Current BSID: 2401:2:1000:B:0:1:0:9 Explicit BSID: -          Dynamic BSID: 2401:2:1000:B:0:1:0:9
 Reference counts: 4
 Flags: A/BS/NC
 Status: Up
 AdminStatus: Not configured
 Up time: 2026-06-29 03:59:40
 Down time: 2026-06-29 03:59:40
 Hot backup: Not configured
 Statistics: Not configured
 SBFD: Not configured
 BFD Echo: Not configured
 Forwarding index: 2150629377
 Service-class: -
 Candidate paths state: Configured
 Candidate paths statistics:
  CLI paths: 1          BGP paths: 0          PCEP paths: 0
 Candidate paths:
  Preference : 100
   CPathName:
   Instance ID: 0          ASN: 0          Node address: 0.0.0.0
   Peer address:  ::
   Optimal: Y              Flags: V/A
   Explicit SID list:
    ID: 1                     Name: l-c-a
    Weight: 100               Forwarding index: 2149580801
    State: Up                 State(-): -
<R11>
