查看: 759|回复: 2
防火墙双活OSPF+VRRP经典组网
背景:
SW1为PC1的网关,SW2为PC2的网关,防火墙为双活组网,出口路由器连接两个ISP网络,通过主备静态路由来控制访问,拓扑图如下:
配置如下:
SW1:
sysname SW1
vlan batch 10 20 100 to 102 201 to 202
cluster enable
ntdp enable
ndp enable
drop illegal-mac alarm
diffserv domain default
ip vpn-instance VPN_A
 ipv4-family
  route-distinguisher 100:1
ip vpn-instance VPN_B
 ipv4-family
  route-distinguisher 100:2
stp region-configuration
 instance 1 vlan 10
 instance 2 vlan 20
 active region-configuration
drop-profile default
aaa
 authentication-scheme default
 authorization-scheme default
 accounting-scheme default
 domain default
 domain default_admin
 local-user admin password simple admin
 local-user admin service-type http
interface Vlanif1
interface Vlanif10
 ip binding vpn-instance VPN_A
 ip address 192.168.10.252 255.255.255.0
 vrrp vrid 10 virtual-ip 192.168.10.254
 vrrp vrid 10 priority 150
interface Vlanif20
 ip binding vpn-instance VPN_B
 ip address 192.168.20.252 255.255.255.0
 vrrp vrid 20 virtual-ip 192.168.20.254
interface Vlanif100
 ip address 10.1.100.1 255.255.255.252
 ospf network-type p2p
interface Vlanif101
 ip address 10.1.10.1 255.255.255.252
interface Vlanif102
 ip address 10.1.10.5 255.255.255.252
interface Vlanif201
 ip address 10.1.20.1 255.255.255.252
interface Vlanif202
 ip address 10.1.20.5 255.255.255.252
interface MEth0/0/1
interface Eth-Trunk1
 port link-type trunk
 port trunk allow-pass vlan 10 20
 mode lacp-static
interface Eth-Trunk2
 port trunk allow-pass vlan 101 to 102 201 to 202
 mode lacp-static
interface GigabitEthernet0/0/1
interface GigabitEthernet0/0/2
interface GigabitEthernet0/0/3
interface GigabitEthernet0/0/4
interface GigabitEthernet0/0/5
interface GigabitEthernet0/0/6
interface GigabitEthernet0/0/7
interface GigabitEthernet0/0/8
interface GigabitEthernet0/0/9
interface GigabitEthernet0/0/10
interface GigabitEthernet0/0/11
interface GigabitEthernet0/0/12
interface GigabitEthernet0/0/13
interface GigabitEthernet0/0/14
interface GigabitEthernet0/0/15
 port link-type access
 port default vlan 100
interface GigabitEthernet0/0/16
interface GigabitEthernet0/0/17
 eth-trunk 2
interface GigabitEthernet0/0/18
 eth-trunk 2
interface GigabitEthernet0/0/19
 eth-trunk 1
interface GigabitEthernet0/0/20
 eth-trunk 1
interface GigabitEthernet0/0/21
interface GigabitEthernet0/0/22
interface GigabitEthernet0/0/23
interface GigabitEthernet0/0/24
 port trunk allow-pass vlan 20
interface NULL0
ospf 1 router-id 10.1.1.1
 area 0.0.0.0
  network 10.1.100.1 0.0.0.0
 area 0.0.0.1
  network 10.1.10.5 0.0.0.0
 area 0.0.0.2
  network 10.1.20.5 0.0.0.0
ospf 2 router-id 10.1.2.2 vpn-instance VPN_A
 vpn-instance-capability simple
 area 0.0.0.1
  network 10.1.10.1 0.0.0.0
  network 192.168.10.0 0.0.0.255
ospf 3 router-id 10.1.3.3 vpn-instance VPN_B
 area 0.0.0.2
  network 10.1.20.1 0.0.0.0
  network 192.168.20.0 0.0.0.255
user-interface con 0
user-interface vty 0 4
return
SW2:
sysname SW2
cluster enable
ntdp enable
ndp enable
 ipv4-family
  route-distinguisher 200:1
 ipv4-family
  route-distinguisher 200:2
 instance 1 vlan 10
 instance 2 vlan 20
aaa
 domain default
interface Vlanif1
interface Vlanif10
 ip address 192.168.10.253 255.255.255.0
interface Vlanif20
 ip address 192.168.20.253 255.255.255.0
interface Vlanif100
 ip address 10.1.100.5 255.255.255.252
interface Vlanif101
 ip address 10.1.10.13 255.255.255.252
interface Vlanif102
 ip address 10.1.10.17 255.255.255.252
interface Vlanif201
 ip address 10.1.20.13 255.255.255.252
interface Vlanif202
 ip address 10.1.20.17 255.255.255.252
interface MEth0/0/1
 mode lacp-static
 mode lacp-static
 eth-trunk 2
 eth-trunk 2
 eth-trunk 1
 eth-trunk 1
interface NULL0
ospf 1 router-id 10.2.1.1
 area 0.0.0.0
  network 10.1.100.5 0.0.0.0
 area 0.0.0.1
  network 10.1.10.17 0.0.0.0
 area 0.0.0.2
  network 10.1.20.17 0.0.0.0
ospf 2 router-id 10.2.2.2 vpn-instance VPN_A
 area 0.0.0.1
  network 10.1.10.13 0.0.0.0
ospf 3 router-id 10.2.3.3 vpn-instance VPN_B
 area 0.0.0.2
  network 10.1.20.13 0.0.0.0
return
SW3:
sysname SW3
vlan batch 10 20
cluster enable
ntdp enable
ndp enable
 instance 1 vlan 10
 instance 2 vlan 20
aaa
 domain default
interface Vlanif1
interface MEth0/0/1
interface NULL0
SW4:
sysname SW4
vlan batch 10 20
cluster enable
ntdp enable
ndp enable
 instance 1 vlan 10
 instance 2 vlan 20
aaa
 domain default
interface Vlanif1
interface MEth0/0/1
 port default vlan 20
interface NULL0
FW1:
sysname FW-1
 l2tp domain suffix-separator @
 ipsec sha2 compatible enable
undo telnet server enable
undo telnet ipv6 server enable
 hrp enable
 hrp interface GigabitEthernet1/0/0 remote 1.1.1.2
 hrp standby config enable
 update schedule location-sdb weekly Sun 02:09
 firewall defend action discard
 banner enable
 user-manage web-authentication security port 8887
 undo privacy-statement english
 undo privacy-statement chinese
page-setting
 user-manage security version tlsv1.1 tlsv1.2
password-policy
 level high
user-manage single-sign-on ad
user-manage single-sign-on tsm
user-manage single-sign-on radius
user-manage auto-sync online-user
 web-manager security version tlsv1.1 tlsv1.2
 web-manager enable
 web-manager security enable
firewall dataplane to manageplane application-apperceive default-action drop
 undo ips log merge enable
 decoding uri-cache disable
 update schedule ips-sdb daily 04:26
 update schedule av-sdb daily 04:26
 update schedule sa-sdb daily 04:26
 update schedule cnc daily 04:26
 update schedule file-reputation daily 04:26
vsys enable
resource-class r0
vsys name VPN_A 1
 assign interface Eth-Trunk1.101
 assign interface Eth-Trunk1.102
vsys name VPN_B 2
 assign interface Eth-Trunk1.201
 assign interface Eth-Trunk1.202
 ipv4-family
 ipv6-family
 ipv4-family
 ipv6-family
ip vpn-instance default
 ipv4-family
 time-range worktime
  period-range 08:00:00 to 18:00:00 working-day
ike proposal default
 encryption-algorithm aes-256 aes-192 aes-128
 dh group14
 authentication-algorithm sha2-512 sha2-384 sha2-256
 authentication-method pre-share
 integrity-algorithm hmac-sha2-256
 prf hmac-sha2-256
aaa
 authentication-scheme admin_local
 authentication-scheme admin_radius_local
 authentication-scheme admin_hwtacacs_local
 authentication-scheme admin_ad_local
 authentication-scheme admin_ldap_local
 domain default
  service-type internetaccess ssl-vpn l2tp ike
  internet-access mode password
  reference user current-domain
 manager-user audit-admin
  password cipher @%@%|hvB=24`NY'!#fN<^xq20'PyGMtZ!'vmZYN%4LP,ioMS'P|0@%@%
  service-type web terminal
  level 15
 manager-user api-admin
  password cipher @%@%C;G!<$<sH:wKCS)Q'o[2uY3;/W"=!s26JE&7lgS>ERpEY3>u@%@%
  level 15
 manager-user admin
  password cipher @%@%KUPkBr^cE~qm&hJ3N8%"~PrLqB@=3[cw1S7pjb0zZNF3PrO~@%@%
  level 15
 role system-admin
 role device-admin
 role device-admin(monitor)
 role audit-admin
 bind manager-user audit-admin role audit-admin
 bind manager-user admin role system-admin
 mode lacp-static
 vlan-type dot1q 101
 ip address 10.1.10.2 255.255.255.252
 service-manage ping permit
 vlan-type dot1q 102
 ip address 10.1.10.6 255.255.255.252
 vlan-type dot1q 201
 ip address 10.1.20.2 255.255.255.252
 vlan-type dot1q 202
 ip address 10.1.20.6 255.255.255.252
l2tp-group default-lns
interface GigabitEthernet0/0/0
 undo shutdown
 ip binding vpn-instance default
 ip address 192.168.0.1 255.255.255.0
 alias GE0/METH
 undo shutdown
 ip address 1.1.1.1 255.255.255.252
interface GigabitEthernet1/0/1
 undo shutdown
 eth-trunk 1
interface GigabitEthernet1/0/2
 undo shutdown
 eth-trunk 1
interface GigabitEthernet1/0/3
 undo shutdown
interface GigabitEthernet1/0/4
 undo shutdown
interface GigabitEthernet1/0/5
 undo shutdown
interface GigabitEthernet1/0/6
 undo shutdown
interface Virtual-if0
interface Virtual-if1
interface Virtual-if2
interface NULL0
firewall zone local
 set priority 100
firewall zone trust
 set priority 85
 add interface GigabitEthernet0/0/0
firewall zone untrust
 set priority 5
firewall zone dmz
 set priority 50
 add interface GigabitEthernet1/0/0
ospf 1 router-id 10.1.5.5 vpn-instance VPN_A
 area 0.0.0.1
  network 10.1.10.2 0.0.0.0
  network 10.1.10.6 0.0.0.0
ospf 2 router-id 10.1.6.6 vpn-instance VPN_B
 area 0.0.0.2
  network 10.1.20.2 0.0.0.0
  network 10.1.20.6 0.0.0.0
undo ssh server compatible-ssh1x enable
ssh authentication-type default password
ssh server cipher aes256_ctr aes128_ctr
ssh server hmac sha2_256 sha1
ssh client cipher aes256_ctr aes128_ctr
ssh client hmac sha2_256 sha1
firewall detect ftp
 authentication-mode aaa
 idle-timeout 1440 0
 protocol inbound ssh
user-interface vty 16 20
pki realm default
sa
location
multi-linkif
 mode proportion-of-weight
right-manager server-group
device-classification
 device-group pc
 device-group mobile-terminal
 device-group undefined-group
user-manage server-sync tsm
security-policy
auth-policy
traffic-policy
policy-based-route
nat-policy
quota-policy
pcp-policy
dns-transparent-policy
rightm-policy
return
switch vsys VPN_A
page-setting
password-policy
 level high
 time-range worktime
aaa
 domain default
 role system-admin
 role device-admin
 role audit-admin
 vlan-type dot1q 101
 vlan-type dot1q 102
sa
firewall zone local
 set priority 100
firewall zone trust
 set priority 85
 add interface Eth-Trunk1.101
 set priority 5
 add interface Eth-Trunk1.102
firewall zone dmz
 set priority 50
location
multi-linkif
security-policy
 default action permit
auth-policy
traffic-policy
policy-based-route
nat-policy
quota-policy
pcp-policy
return
switch vsys VPN_B
page-setting
password-policy
 level high
 time-range worktime
aaa
 domain default
 role system-admin
 role device-admin
 role audit-admin
 vlan-type dot1q 201
 vlan-type dot1q 202
sa
firewall zone local
 set priority 100
firewall zone trust
 set priority 85
 add interface Eth-Trunk1.201
 set priority 5
 add interface Eth-Trunk1.202
firewall zone dmz
 set priority 50
location
multi-linkif
security-policy
auth-policy
traffic-policy
policy-based-route
nat-policy
quota-policy
pcp-policy
FW2:
sysname FW-2
 hrp enable
 hrp interface GigabitEthernet1/0/0 remote 1.1.1.1
 update schedule location-sdb weekly Sun 22:13
 banner enable
page-setting
password-policy
 level high
 web-manager enable
 update schedule ips-sdb daily 02:14
 update schedule av-sdb daily 02:14
 update schedule sa-sdb daily 02:14
 update schedule cnc daily 02:14
 update schedule file-reputation daily 02:14
vsys enable
resource-class r0
vsys name VPN_A 1
vsys name VPN_B 2
 ipv4-family
 ipv6-family
 ipv4-family
 ipv6-family
 ipv4-family
 time-range worktime
 dh group14
 prf hmac-sha2-256
aaa
 domain default
  password cipher @%@%*1(!B`YHyM5l3%E<+UL+bYWL0!8wN}BsAE&3fT@}P\pLYWOb@%@%
  level 15
  password cipher @%@%3\lj6#2r]J~CspEUi3O(I8ut<Pl3K0//cBtsWw>dRdM~8uwI@%@%
  level 15
 manager-user admin
  password cipher @%@%Bl^S!nEGz&Gmjo7sp,i"bX5,ybR|&N}T8YHdA+13>HLAX5/b@%@%
  level 15
 role system-admin
 role device-admin
 role audit-admin
 mode lacp-static
 vlan-type dot1q 101
 ip address 10.1.10.14 255.255.255.252
 vlan-type dot1q 102
 ip address 10.1.10.18 255.255.255.252
 vlan-type dot1q 201
 ip address 10.1.20.14 255.255.255.252
 vlan-type dot1q 202
 ip address 10.1.20.18 255.255.255.252
 undo shutdown
 alias GE0/METH
 undo shutdown
 ip address 1.1.1.2 255.255.255.252
 undo shutdown
 eth-trunk 1
 undo shutdown
 eth-trunk 1
 undo shutdown
 undo shutdown
 undo shutdown
 undo shutdown
interface NULL0
firewall zone local
 set priority 100
firewall zone trust
 set priority 85
 set priority 5
firewall zone dmz
 set priority 50
ospf 1 router-id 10.2.5.5 vpn-instance VPN_A
 area 0.0.0.1
  network 10.1.10.14 0.0.0.0
  network 10.1.10.18 0.0.0.0
ospf 2 router-id 10.2.6.6 vpn-instance VPN_B
 area 0.0.0.2
  network 10.1.20.14 0.0.0.0
  network 10.1.20.18 0.0.0.0
firewall detect ftp
 idle-timeout 1440 0
pki realm default
sa
location
multi-linkif
 device-group pc
security-policy
auth-policy
traffic-policy
policy-based-route
nat-policy
quota-policy
pcp-policy
rightm-policy
return
switch vsys VPN_A
page-setting
password-policy
 level high
 time-range worktime
aaa
 domain default
 role system-admin
 role device-admin
 role audit-admin
 vlan-type dot1q 101
 vlan-type dot1q 102
sa
firewall zone local
 set priority 100
firewall zone trust
 set priority 85
 set priority 5
firewall zone dmz
 set priority 50
location
multi-linkif
security-policy
auth-policy
traffic-policy
policy-based-route
nat-policy
quota-policy
pcp-policy
return
switch vsys VPN_B
page-setting
password-policy
 level high
 time-range worktime
aaa
 domain default
 role system-admin
 role device-admin
 role audit-admin
 vlan-type dot1q 201
 vlan-type dot1q 202
sa
firewall zone local
 set priority 100
firewall zone trust
 set priority 85
 set priority 5
firewall zone dmz
 set priority 50
location
multi-linkif
security-policy
auth-policy
traffic-policy
policy-based-route
nat-policy
quota-policy
pcp-policy
AR1:
sysname R1
 snmp-agent local-engineid 800007DB03000000000000
 snmp-agent
 clock timezone China-Standard-Time minus 08:00:00
portal local-server load portalpage.zip
 set cpu-usage threshold 80 restore 75
acl number 2000
 rule 5 permit source 192.168.10.0 0.0.0.255
 rule 10 permit source 192.168.20.0 0.0.0.255
aaa
 domain default
 local-user admin password cipher %$%$K8m.Nt84DZ}e#<0`8bmE3Uw}%$%$
firewall zone Local
 priority 15
 ip address 10.255.1.1 255.255.255.0
 vrrp vrid 1 virtual-ip 10.255.1.3
 vrrp vrid 1 priority 150
 nat outbound 2000
 ip address 10.1.100.2 255.255.255.252
 ip address 10.255.2.1 255.255.255.0
 vrrp vrid 2 virtual-ip 10.255.2.3
 nat outbound 2000
interface NULL0
ospf 1
 default-route-advertise
 area 0.0.0.0
  network 10.1.100.2 0.0.0.0
ip route-static 0.0.0.0 0.0.0.0 10.255.1.254
ip route-static 0.0.0.0 0.0.0.0 10.255.2.254 preference 100
 authentication-mode password
wlan ac
AR2:
sysname R2
 snmp-agent
acl number 2000
aaa
 domain default
firewall zone Local
 priority 15
 ip address 10.255.1.2 255.255.255.0
 nat outbound 2000
 ip address 10.1.100.6 255.255.255.252
 ip address 10.255.2.2 255.255.255.0
 vrrp vrid 2 priority 150
 nat outbound 2000
interface NULL0
ospf 1
 area 0.0.0.0
  network 10.1.100.6 0.0.0.0
ip route-static 0.0.0.0 0.0.0.0 10.255.1.254 preference 100
wlan ac
测试效果为PC访问ISP1,PC2f访问ISP2:
PC>ping 8.8.8.8
Ping 8.8.8.8: 32 data bytes, Press Ctrl_C to break
From 8.8.8.8: bytes=32 seq=1 ttl=251 time=110 ms
From 8.8.8.8: bytes=32 seq=2 ttl=251 time=78 ms
From 8.8.8.8: bytes=32 seq=3 ttl=251 time=109 ms
From 8.8.8.8: bytes=32 seq=4 ttl=251 time=78 ms
From 8.8.8.8: bytes=32 seq=5 ttl=251 time=110 ms
--- 8.8.8.8 ping statistics ---
  5 packet(s) transmitted
  5 packet(s) received
  0.00% packet loss
  round-trip min/avg/max = 78/97/110 ms
PC>ping 114.114.114.114
Ping 114.114.114.114: 32 data bytes, Press Ctrl_C to break
From 114.114.114.114: bytes=32 seq=1 ttl=251 time=125 ms
From 114.114.114.114: bytes=32 seq=2 ttl=251 time=125 ms
From 114.114.114.114: bytes=32 seq=3 ttl=251 time=94 ms
From 114.114.114.114: bytes=32 seq=4 ttl=251 time=93 ms
From 114.114.114.114: bytes=32 seq=5 ttl=251 time=94 ms
--- 114.114.114.114 ping statistics ---
  0.00% packet loss
  round-trip min/avg/max = 93/106/125 ms
upload 附件:防火墙双活+VRRP组网案例.zip
发表于 2026-6-17 10:15:28 | 显示全部楼层
感谢分享,非常实用。
4万
发表于 2026-6-23 10:22:08 | 显示全部楼层
跟着UP主的配置一点点的复原,结果防火墙虚系统和vpn-instance配置不了,老冲突,不知道配置顺序。HRP_M[FW1-Eth-Trunk1.101]ip binding vpn-instance VPN_A (+B)
Error: The vpn-instance is created by virtual system, can't binding or undo bin
ding with the vpn-instance.
