查看: 514|回复: 1
流量洞察常用Filter语句速查表
1 EVE Pro Network Filter - BPF 过滤表达式完整参考
文档版本: v1.0
创建时间: 2026-06-15
适用版本: EVE-NG Pro 6.4+ / 7.0+
1.1 一、预设协议列表(18 种)
类型 协议 EVE Pro BPF 表达式 IPv4/IPv6 子类型
L2 控制平面 STP/BPDU ether dst 01:80:c2:00:00:00 or ether dst 01:00:0c:cc:cc:cd ❌ L2 ✅ Config/TCN/RSTP
CDP ether dst 01:00:0c:cc:cc:cc and ether[20:2] = 0x2000 ❌ L2 ❌
LLDP ether proto 0x88cc ❌ L2 ❌
IS-IS isis ❌ L2 ✅ Hello/LSP/CSNP/PSNP
802.1Q vlan ❌ L2 ❌
IGP OSPF ip proto 89 ✅ v4 + v6 ✅ Hello/DBD/LSR/LSU/LSAck
EIGRP ip proto 88 ✅ v4 + v6 ✅ Update/Query/Reply/Hello
RIP udp port 520 ✅ v4 + v6 ✅ Request/Response
ICMP ICMP icmp ✅ v4 + v6 ✅ Echo/Dest Unreach/TTL-Exceeded
Ping icmp[0] = 8 or icmp[0] = 0 ✅ v4 + v6 ✅ Echo Request/Reply
EGP BGP tcp port 179 ✅ v4 + v6 ✅ OPEN/UPDATE/NOTIFICATION/KEEPALIVE
Overlay VXLAN udp port 4789 ✅ v4 + v6 ✅ VNI 匹配
LISP udp port 4341 or udp port 4342 ✅ v4 + v6 ✅ Map-Req/Reply/Register
隧道 GRE ip proto 47 ✅ v4 + v6 ❌
安全 IPsec ip proto 50 or ip proto 51 or (udp and (port 500 or port 4500)) ✅ v4 + v6 ✅ ESP/AH/ISAKMP
AAA RADIUS udp and (port 1812 or port 1813 or port 1645 or port 1646) ✅ v4 + v6 ✅ Auth/Acct
TACACS+ tcp port 49 ✅ v4 + v6 ❌
自定义 Custom 用户自定义 BPF ✅ ❌
1.2 二、BPF 过滤表达式详解
1.2.1 2.1 L2 控制平面协议
1.2.1.1 STP / BPDU
# IEEE 802.1D STP + Cisco PVST+/RSTP
子类型:
子类型 BPF 表达式
Config (0x00) (ether dst 01:80:c2:00:00:00 and ether[20]=0x00) or (ether dst 01:00:0c:cc:cc:cd and ether[25]=0x00) or (vlan and ether dst 01:00:0c:cc:cc:cd and ether[29]=0x00)
TCN (0x80) (ether dst 01:80:c2:00:00:00 and ether[20]=0x80) or (ether dst 01:00:0c:cc:cc:cd and ether[25]=0x80) or (vlan and ether dst 01:00:0c:cc:cc:cd and ether[29]=0x80)
RSTP (0x02) (ether dst 01:80:c2:00:00:00 and ether[20]=0x02) or (ether dst 01:00:0c:cc:cc:cd and ether[25]=0x02) or (vlan and ether dst 01:00:0c:cc:cc:cd and ether[29]=0x02)
1.2.1.2 CDP (Cisco Discovery Protocol)
1.2.1.3 LLDP (Link Layer Discovery Protocol)
ether proto 0x88cc
1.2.1.4 IS-IS
isis
子类型:
子类型 PDU 类型 BPF 表达式
Hello 15/16/17 isis and ((ether[21] & 0x1f) = 15 or (ether[21] & 0x1f) = 16 or (ether[21] & 0x1f) = 17)
LSP 18/20 isis and ((ether[21] & 0x1f) = 18 or (ether[21] & 0x1f) = 20)
CSNP 24/25 isis and ((ether[21] & 0x1f) = 24 or (ether[21] & 0x1f) = 25)
PSNP 26/27 isis and ((ether[21] & 0x1f) = 26 or (ether[21] & 0x1f) = 27)
1.2.1.5 802.1Q (VLAN)
vlan
1.2.2 2.2 IGP 协议
1.2.2.1 OSPF
# IPv4
ip proto 89
# IPv6
ip6 proto 89
子类型:
子类型 类型字节 IPv4 BPF IPv6 BPF
Hello 1 ip proto 89 and ip[((ip[0]&0xf)<<2)+1]=1 ip6 proto 89 and ip6[41]=1
DBD 2 ip proto 89 and ip[((ip[0]&0xf)<<2)+1]=2 ip6 proto 89 and ip6[41]=2
LSR 3 ip proto 89 and ip[((ip[0]&0xf)<<2)+1]=3 ip6 proto 89 and ip6[41]=3
LSU 4 ip proto 89 and ip[((ip[0]&0xf)<<2)+1]=4 ip6 proto 89 and ip6[41]=4
LSAck 5 ip proto 89 and ip[((ip[0]&0xf)<<2)+1]=5 ip6 proto 89 and ip6[41]=5
偏移量计算:
  • ip[0]&0xf = IHL(IP 头长度,低 4 位,单位 4 字节)
  • ((ip[0]&0xf)<<2) = IP 头长度(字节)
  • +1 = OSPF 类型字段偏移
1.2.2.2 EIGRP
# IPv4
ip proto 88
# IPv6
ip6 proto 88
子类型 (⚠️ 仅 IPv4):
子类型 OpCode BPF 表达式
Update 1 ip proto 88 and ip[((ip[0]&0xf)<<2)+1]=1
Query 3 ip proto 88 and ip[((ip[0]&0xf)<<2)+1]=3
Reply 4 ip proto 88 and ip[((ip[0]&0xf)<<2)+1]=4
Hello/Ack 5 ip proto 88 and ip[((ip[0]&0xf)<<2)+1]=5
SIA-Query 10 ip proto 88 and ip[((ip[0]&0xf)<<2)+1]=10
SIA-Reply 11 ip proto 88 and ip[((ip[0]&0xf)<<2)+1]=11
1.2.2.3 RIP
# IPv4
udp port 520
# IPv6 (RIPng)
udp port 521
子类型 (⚠️ 仅 IPv4):
子类型 Command BPF 表达式
Request 1 udp port 520 and udp[8]=1
Response 2 udp port 520 and udp[8]=2
1.2.3 2.3 ICMP 协议
1.2.3.1 ICMP
# IPv4
icmp
# IPv6
icmp6
子类型:
子类型 IPv4 Type IPv6 Type IPv4 BPF IPv6 BPF
Echo Request 8 128 icmp[icmptype]=8 icmp6 and ip6[40]=128
Echo Reply 0 129 icmp[icmptype]=0 icmp6 and ip6[40]=129
Dest Unreachable 3 1 icmp[icmptype]=3 icmp6 and ip6[40]=1
TTL Exceeded 11 3 icmp[icmptype]=11 icmp6 and ip6[40]=3
Redirect 5 - icmp[icmptype]=5 ❌
1.2.3.2 Ping (Echo)
# IPv4
# IPv6
icmp6 and (ip6[40] = 128 or ip6[40] = 129)
1.2.4 2.4 EGP 协议
1.2.4.1 BGP
tcp port 179
子类型 (⚠️ 仅 IPv4):
子类型 消息类型 BPF 表达式
OPEN 1 tcp port 179 and tcp[((tcp[12]&0xf0)>>2)+18]=1
UPDATE 2 tcp port 179 and tcp[((tcp[12]&0xf0)>>2)+18]=2
NOTIFICATION 3 tcp port 179 and tcp[((tcp[12]&0xf0)>>2)+18]=3
KEEPALIVE 4 tcp port 179 and tcp[((tcp[12]&0xf0)>>2)+18]=4
偏移量计算:
  • tcp[12]&0xf0 = TCP 数据偏移(高 4 位,单位 4 字节)
  • ((tcp[12]&0xf0)>>2) = TCP 头长度(字节)
  • +18 = BGP 消息头的 Type 字段偏移
1.2.5 2.5 Overlay 协议
1.2.5.1 VXLAN
# 基础匹配
udp port 4789
VNI 匹配:
写法 表达式 说明
3 字节比对(Pro 7.8+) ether[46:3] == 0xVVVVVV 简洁,EVE-NG Pro 78 支持
2+1 字节拆分(通用) ether[46:2] == 0xXXXX and ether[48] == 0xXX 兼容性最好
VNI 速查:
VNI 十六进制 3 字节写法 2+1 字节写法
10000 0x002710 ether[46:3] == 0x002710 ether[46:2] == 0x0027 and ether[48] == 0x10
20000 0x004E20 ether[46:3] == 0x004E20 ether[46:2] == 0x004E and ether[48] == 0x20
5001 0x001389 ether[46:3] == 0x001389 ether[46:2] == 0x0013 and ether[48] == 0x89
90000 0x015F90 ether[46:3] == 0x015F90 ether[46:2] == 0x015F and ether[48] == 0x90
91000 0x016378 ether[46:3] == 0x016378 ether[46:2] == 0x0163 and ether[48] == 0x78
完整示例 (VXLAN + VLAN + 源网络):
# VXLAN VNI 90000,Tenant-A 网络 172.16.0.0/16
(src net 172.16.0.0/16 and icmp) or
(udp port 4789 and ether[46:3] == 0x015F90 and ether[73] == 1) or
(vlan and src net 172.16.0.0/16 and icmp)
1.2.5.2 LISP
子类型 (⚠️ 仅 IPv4):
子类型 消息类型 BPF 表达式
Map-Request 0x10 udp dst port 4342 and (udp[8]&0xf0)=0x10
Map-Reply 0x20 udp dst port 4342 and (udp[8]&0xf0)=0x20
Map-Register 0x30 udp dst port 4342 and (udp[8]&0xf0)=0x30
Map-Notify 0x40 udp dst port 4342 and (udp[8]&0xf0)=0x40
1.2.6 2.6 隧道协议
1.2.6.1 GRE
# IPv4
ip proto 47
# IPv6
ip6 proto 47
1.2.7 2.7 安全协议
1.2.7.1 IPsec
# IPv4
ip proto 50 or ip proto 51 or (ip and udp and (port 500 or port 4500))
# IPv6
ip6 proto 50 or ip6 proto 51 or (ip6 and udp and (port 500 or port 4500))
子类型:
子类型 协议 IPv4 BPF IPv6 BPF
ESP 50 ip proto 50 ip6 proto 50
AH 51 ip proto 51 ip6 proto 51
ISAKMP/IKE UDP 500/4500 udp and (port 500 or port 4500) ip6 and udp and (port 500 or port 4500)
1.2.7.2 RADIUS
子类型:
子类型 端口 BPF 表达式
Auth 1812/1645 udp and (port 1812 or port 1645)
Acct 1813/1646 udp and (port 1813 or port 1646)
1.2.7.3 TACACS+
tcp port 49
1.3 三、BPF 表达式构建指南
1.3.1 3.1 核心构建模板
(核心表达式) and (可选条件1) and (可选条件2) ...
可选条件:
  • src host <IP> - 源 IP
  • dst host <IP> - 目的 IP
  • src net <CIDR> - 源网段
  • dst net <CIDR> - 目的网段
  • port <N> - 端口
  • tcp / udp / icmp - L4 协议
1.3.2 3.2 VLAN 支持(必须手动添加)
如果协议可能通过 VLAN 传输,需要手动添加 VLAN 分支:
# 基础(无 VLAN)
# 完整(支持 VLAN)
(udp port 4789 and ether[46:3] == 0x015F90) or (vlan and udp port 4789 and ether[46:3] == 0x015F90)
1.3.3 3.3 OR 表达式中 vlan 必须放最后
# ✅ 正确:vlan 放最后
icmp[0] == 8 or (udp port 4789 and ether[84] == 8) or (vlan and icmp[0] == 8)
# ❌ 错误:vlan 在中间
icmp[0] == 8 or (vlan and icmp[0] == 8) or (udp port 4789 and ether[84] == 8)
原因: vlan 关键字会永久改变 BPF 偏移寄存器,导致后续分支基于错误基准点计算。
1.4 四、实战示例
1.4.1 4.1 示例 1:OSPF Hello(IPv4,源 IP 10.0.0.1)
(ip proto 89 and ip[((ip[0]&0xf)<<2)+1]=1) and src host 10.0.0.1
1.4.2 4.2 示例 2:BGP UPDATE 消息(IPv4)
1.4.3 4.3 示例 3:VXLAN VNI 5001
# 基础(无 VLAN)
udp port 4789 and ether[46:3] == 0x001389
# 完整(支持 VLAN)
(udp port 4789 and ether[46:3] == 0x001389) or (vlan and udp port 4789 and ether[46:3] == 0x001389)
1.4.4 4.4 示例 4:Tenant-A ICMP 流量(VXLAN+VLAN+裸包)
# Tenant-A: VNI 90000, 网络 172.16.0.0/16
1.4.5 4.5 示例 5:RADIUS Auth + Acct
1.5 五、缺失协议补充
以下协议不在预设列表中,可使用自定义 BPF:
协议 用途 BPF 表达式
ARP 地址解析 arp或 ether proto 0x0806
NDP IPv6 地址解析 icmp6 and (ip6[40]=135 or ip6[40]=136)
LDP MPLS 标签分发 udp port 646
RSVP MPLS TE ip proto 46
BFD 双向转发检测 udp port 3784 or udp port 3785
VRRP 虚拟路由器冗余 ip proto 112
HSRP Cisco 热备 udp port 1985
1.6 六、BPF 语法速查
1.6.1 6.1 基本语法
语法 说明 示例
host <IP> 源或目的 IP host 10.0.0.1
src host <IP> 源 IP src host 10.0.0.1
dst host <IP> 目的 IP dst host 10.0.0.2
net <CIDR> 网段 net 172.16.0.0/16
port <N> 端口 port 179
proto <N> IP 协议号 proto 89(OSPF)
vlan 802.1Q 标记 vlan and ip
and/or/not 逻辑运算符 ip and tcp and not port 22
1.6.2 6.2 字节匹配
语法 说明 示例
ip[n] IPv4 头第 n 字节 ip[0]= Version + IHL
ip6[n] IPv6 头第 n 字节 ip6[40]= Next Header 后第一个字节
tcp[n] TCP 头第 n 字节 tcp[12]= Data Offset + Flags
udp[n] UDP 头第 n 字节 udp[8]= LISP Type
ether[n] Ethernet 头第 n 字节 ether[46]= VXLAN VNI 高字节
ip[n:m] 从 n 开始取 m 字节 ip[20:4]= Source Address
udp[n:m] 从 n 开始取 m 字节 udp[12:4]= VXLAN 头
1.6.3 6.3 位运算
语法 说明 示例
& 按位与 ip[0]&0xf= IHL
<< 左移 (ip[0]&0xf)<<2= IP 头长度(字节)
>> 右移 (udp[12:4]>>8)= VNI 高 24 位
1.7 七、BPF 黄金法则
1.7.1 法则 1️⃣:VNI 必须拆分
# ❌ 错误:3 字节比对
# ✅ 正确:拆分为 2+1 字节
1.7.2 法则 2️⃣:OR 中 vlan 必须放最后
# ✅ 正确
icmp[0] == 8 or (udp ...) or (vlan and icmp[0] == 8)
# ❌ 错误
vlan and icmp[0] == 8 or icmp[0] == 8 or (udp ...)
1.7.3 法则 3️⃣:括号具有作用域隔离
# ✅ 递归嵌套:vlan 指针各自独立
arp or (vlan and (arp or (vlan and arp)))
# ❌ 平铺展开:多 vlan 并列导致偏移混乱
arp or (vlan and arp) or (vlan and vlan and arp)
文档状态: ✅ 完成
发表于 2026-8-12 19:41:01 | 显示全部楼层
宝 不更新了吗
