查看: 721|回复: 2
电脑的CRT、xshell软件怎么登录eve-ng模拟器
新手学习中,各位大佬知道怎么通过PC本地ssh软件去登录虚拟机eve-ng吗?
发表于 2026-2-11 00:35:08 | 显示全部楼层
发表于 2026-2-17 09:23:34 | 显示全部楼层
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\SOFTWARE\Classes\Xshell.telnet]
@="telnet"
[HKEY_CURRENT_USER\SOFTWARE\Classes\Xshell.telnet\DefaultIcon]
@="C:\Program Files (x86)\NetSarang\Xshell 8\xshell.exe,0"
[HKEY_CURRENT_USER\SOFTWARE\Classes\Xshell.telnet\shell]
[HKEY_CURRENT_USER\SOFTWARE\Classes\Xshell.telnet\shell\open]
[HKEY_CURRENT_USER\SOFTWARE\Classes\Xshell.telnet\shell\open\command]
@=""C:\Program Files (x86)\NetSarang\Xshell 8\xshell.exe" -url "%1""
[HKEY_CURRENT_USER\SOFTWARE\Xshell]
[HKEY_CURRENT_USER\SOFTWARE\Xshell\Capabilities]
[HKEY_CURRENT_USER\SOFTWARE\Xshell\Capabilities\URLAssociations]
"telnet"="Xshell.telnet"
[HKEY_CURRENT_USER\SOFTWARE\RegisteredApplications]
"Xshell"="Software\Xshell\Capabilities"
[HKEY_CURRENT_USER\SOFTWARE\Classes\telnet\shell]
[HKEY_CURRENT_USER\SOFTWARE\Classes\telnet\shell\open]
[HKEY_CURRENT_USER\SOFTWARE\Classes\telnet\shell\open\command]
[HKEY_CLASSES_ROOT\Xshell.telnet\DefaultIcon]
[HKEY_CLASSES_ROOT\Xshell.telnet\shell]
[HKEY_CLASSES_ROOT\Xshell.telnet\shell\open]
[HKEY_CLASSES_ROOT\Xshell.telnet\shell\open\command]
[HKEY_LOCAL_MACHINE\SOFTWARE\Xshell]
[HKEY_LOCAL_MACHINE\SOFTWARE\Xshell\capabilities]
[HKEY_LOCAL_MACHINE\SOFTWARE\Xshell\capabilities\URLassociations]
[HKEY_LOCAL_MACHINE\SOFTWARE\RegisteredApplications]
"xshell"="software\Xshell\capabilities"
复制这段,保存为reg注册表文件
复制后,保存前,发给豆包,让豆包帮你改一下你电脑的xshell路径,把这段内容和你电脑的xshell路径提供给豆包,豆包就给你调整了,调整后,在复制下来保存为reg文件,然后双击运行一下
