查看: 1293|回复: 1
【案例分享】思科EVPN标准数据中心测试
1、网络拓扑
标准的Spine-Leaf架构,防火墙使用ASA,采用HSRP实现双机冗余
2、设备配置,注标红命令,表示需要重启才能生效。
(1)Cisco-PE01
hostname PE01
interface Loopback0
 ip address 88.1.1.1 255.255.255.255
interface Ethernet1/0
 ip address 172.16.1.1 255.255.255.252
 ip ospf network point-to-point
 duplex full
interface Ethernet1/1
 ip address 172.16.2.1 255.255.255.252
 duplex full
router ospf 101
 router-id 88.1.1.1
 redistribute connected subnets
 network 172.16.1.1 0.0.0.0 area 0
 network 172.16.2.1 0.0.0.0 area 0
(2)Cisco-BL01
hostname Cisco-BL01
cfs eth distribute
nv overlay evpn
feature ospf
feature bgp
feature pim
feature fabric forwarding
feature interface-vlan
feature vn-segment-vlan-based
feature lacp
feature vpc
feature lldp
feature bfd
feature nv overlay
fabric forwarding anycast-gateway-mac 0001.0001.0001
ip pim rp-address 8.8.8.8 group-list 239.0.0.0/24
ip pim ssm range 232.0.0.0/8
vlan 1,10,20,101-102
vlan 10
  vn-segment 10
vlan 20
  vn-segment 20
vlan 101
  vn-segment 101
evpn
  vni 10 l2
    rd auto
    route-target import auto
    route-target export auto
  vni 20 l2
    rd auto
ip prefix-list PC01 seq 5 permit 10.18.1.0/24
ip prefix-list PC02 seq 5 permit 10.18.2.0/24
ip prefix-list default seq 5 permit 0.0.0.0/0
route-map PC permit 10
  match ip address prefix-list PC01 PC02
route-map default permit 10
  match ip address prefix-list default
vrf context gw_vpna
  ip route 10.18.1.0/24 172.17.12.2
  ip route 10.18.2.0/24 172.17.12.2
  rd auto
vrf context heart
vrf context management
vrf context vpna
  vni 101
  ip route 0.0.0.0/0 172.17.11.2
  rd auto
  address-family ipv4 unicast
    route-target both auto
    route-target both auto evpn
hardware access-list tcam region racl 512
hardware access-list tcam region arp-ether 256 double-wide
vpc domain 100
  peer-switch
  role priority 150
  system-priority 100
  peer-keepalive destination 192.168.1.2 source 192.168.1.1 vrf heart
  peer-gateway
interface Vlan10
  no shutdown
  vrf member vpna
  ip address 172.17.11.1/30
  fabric forwarding mode anycast-gateway
interface Vlan101
  no shutdown
  vrf member vpna
  ip forward
interface Vlan102
  no shutdown
  vrf member gw_vpna
  ip address 172.17.12.1/30
interface port-channel1
  switchport mode trunk
  switchport trunk allowed vlan 10,102
  vpc 1
interface port-channel2
  vpc 2
interface port-channel100
  description peer-link
  spanning-tree port type network
  vpc peer-link
router ospf 100
  router-id 21.1.1.1
router ospf 101
  vrf gw_vpna
    router-id 21.1.1.1
    redistribute static route-map PC
  no switchport
  vrf member gw_vpna
  ip address 172.16.1.2/30
  ip router ospf 101 area 0.0.0.0
  no shutdown
interface Ethernet1/2
  no switchport
  ip address 172.17.1.1/30
  ip router ospf 100 area 0.0.0.0
  ip pim sparse-mode
  no shutdown
interface Ethernet1/3
  no switchport
  ip address 172.17.2.1/30
  ip pim sparse-mode
  no shutdown
interface Ethernet1/4
  channel-group 1 mode active
interface Ethernet1/5
  channel-group 2 mode active
interface Ethernet1/6
  channel-group 100 mode active
interface Ethernet1/7
  no switchport
  no shutdown
interface Ethernet1/7.10
  description for heart
  encapsulation dot1q 10
  vrf member heart
  ip address 192.168.1.1/30
  no shutdown
interface Ethernet1/7.20
  description for escape
  encapsulation dot1q 20
  vrf member gw_vpna
  ip address 172.16.3.1/30
  ip ospf cost 1000
  no shutdown
interface loopback0
  ip address 21.1.1.1/32
  ip pim sparse-mode
interface loopback1
  ip address 21.1.2.1/32
  ip address 20.1.1.1/32 secondary
  ip pim sparse-mode
interface nve1
  no shutdown
  host-reachability protocol bgp
  source-interface loopback1
  member vni 10
    suppress-arp
    mcast-group 239.0.0.1
  member vni 20
    suppress-arp
  member vni 101 associate-vrf
router bgp 100
  log-neighbor-changes
  template peer spine
    remote-as 100
    update-source loopback0
    address-family l2vpn evpn
      send-community extended
  neighbor 22.1.1.1
    inherit peer spine
  neighbor 22.1.1.2
    inherit peer spine
  vrf vpna
      advertise l2vpn evpn
      redistribute static route-map default
      default-information originate
(3)Cisco-BL02
hostname Cisco-BL02
cfs eth distribute
nv overlay evpn
feature ospf
feature bgp
feature pim
feature lacp
feature vpc
feature lldp
feature bfd
feature nv overlay
vlan 10
  vn-segment 10
vlan 20
  vn-segment 20
vlan 101
  vn-segment 101
evpn
  vni 10 l2
    rd auto
  vni 20 l2
    rd auto
vrf context gw_vpna
  rd auto
vrf context heart
vrf context vpna
  vni 101
  rd auto
vpc domain 100
  peer-switch
  role priority 150
  system-priority 100
  peer-keepalive destination 192.168.1.1 source 192.168.1.2 vrf heart
  peer-gateway
interface Vlan10
  no shutdown
  vrf member vpna
  no ip redirects
  no ipv6 redirects
interface Vlan101
  no shutdown
  vrf member vpna
  no ip redirects
  ip forward
  no ipv6 redirects
interface Vlan102
  no shutdown
  vrf member gw_vpna
  no ip redirects
  no ipv6 redirects
  vpc 1
  vpc 2
  vpc peer-link
router ospf 100
  router-id 21.1.1.2
router ospf 101
  vrf gw_vpna
    router-id 21.1.1.2
  no switchport
  vrf member gw_vpna
  ip address 172.16.2.2/30
  no shutdown
  no switchport
  ip address 172.17.3.1/30
  ip pim sparse-mode
  no shutdown
  no switchport
  ip address 172.17.4.1/30
  ip pim sparse-mode
  no shutdown
  no switchport
  no shutdown
  vrf member heart
  ip address 192.168.1.2/30
  no shutdown
  vrf member gw_vpna
  ip address 172.16.3.2/30
  ip ospf cost 1000
  no shutdown
interface loopback0
  ip address 21.1.1.2/32
  ip pim sparse-mode
interface loopback1
  ip address 21.1.2.2/32
  ip pim sparse-mode
interface nve1
  no shutdown
  member vni 10
    suppress-arp
  member vni 20
    suppress-arp
router bgp 100
  template peer spine
    remote-as 100
  neighbor 22.1.1.1
    inherit peer spine
  neighbor 22.1.1.2
    inherit peer spine
  vrf vpna
(4)Cisco-FW01
hostname Ciso-FW01
interface Ethernet0
 channel-group 1 mode passive
 no shutdown
interface Ethernet1
 no shutdown
interface Ethernet2
 no shutdown
interface Port-channel1
interface Port-channel1.10
 vlan 10
 nameif inside
 ip address 172.17.11.2 255.255.255.248 standby 172.17.11.3
interface Port-channel1.102
 vlan 102
 nameif outside
 ip address 172.17.12.2 255.255.255.248 standby 172.17.12.3
route outside 0.0.0.0 0.0.0.0 172.17.12.1 1
route inside 10.18.1.0 255.255.255.0 172.17.11.1 1
route inside 10.18.2.0 255.255.255.0 172.17.11.1 1
access-list ping extended permit icmp any any
access-group ping in interface outside
==================failover
failover
failover lan unit primary
failover lan interface flink Ethernet2
failover key nihao
failover replication http
failover link flink Ethernet2
failover interface ip flink 192.168.1.1 255.255.255.252 standby 192.168.1.2
(5)Csico-FW02
hostname Ciso-FW02
interface Ethernet2
 no shutdown
failover
failover lan unit secondary
failover key nihao
(6)Cisco-SP01
hostname Cisco-SP01
nv overlay evpn
feature ospf
feature bgp
feature pim
feature lldp
feature bfd
ip pim anycast-rp 8.8.8.8 22.1.1.1
ip pim anycast-rp 8.8.8.8 22.1.1.2
router ospf 100
  router-id 22.1.1.1
  no switchport
  ip address 172.17.1.2/30
  ip pim sparse-mode
  no shutdown
  no switchport
  ip address 172.17.3.2/30
  ip pim sparse-mode
  no shutdown
  no switchport
  ip address 172.17.5.1/30
  ip pim sparse-mode
  no shutdown
  no switchport
  ip address 172.17.7.1/30
  ip pim sparse-mode
  no shutdown
interface loopback0
  description R-ID
  ip address 22.1.1.1/32
  ip pim sparse-mode
interface loopback1
  description anycast-rp
  ip address 8.8.8.8/32
  ip pim sparse-mode
router bgp 100
  template peer leaf
    remote-as 100
      route-reflector-client
  neighbor 11.1.1.1
    inherit peer leaf
  neighbor 11.1.1.2
    inherit peer leaf
  neighbor 21.1.1.1
    inherit peer leaf
  neighbor 21.1.1.2
    inherit peer leaf
(7)Cisco-SP02
hostname Cisco-SP02
nv overlay evpn
feature ospf
feature bgp
feature pim
feature lldp
feature bfd
router ospf 100
  router-id 22.1.1.2
  no switchport
  ip address 172.17.2.2/30
  ip pim sparse-mode
  no shutdown
  no switchport
  ip address 172.17.4.2/30
  ip pim sparse-mode
  no shutdown
  no switchport
  ip address 172.17.6.1/30
  ip pim sparse-mode
  no shutdown
  no switchport
  ip address 172.17.8.1/30
  ip pim sparse-mode
  no shutdown
interface loopback0
  description R-ID
  ip address 22.1.1.2/32
  ip pim sparse-mode
interface loopback1
  ip pim sparse-mode
router bgp 100
  template peer leaf
    remote-as 100
  neighbor 11.1.1.1
    inherit peer leaf
  neighbor 11.1.1.2
    inherit peer leaf
  neighbor 21.1.1.1
    inherit peer leaf
  neighbor 21.1.1.2
    inherit peer leaf
(8)Cisco-SL01
hostname Cisco-SL01
cfs eth distribute
nv overlay evpn
feature ospf
feature bgp
feature pim
feature lacp
feature vpc
feature lldp
feature bfd
feature nv overlay
vlan 1,10,20,101
vlan 10
  vn-segment 10
vlan 20
  vn-segment 20
vlan 101
  vn-segment 101
evpn
  vni 10 l2
    rd auto
  vni 20 l2
    rd auto
vrf context heart
vrf context vpna
  vni 101
  rd auto
vpc domain 100
  peer-switch
  role priority 100
  system-priority 100
  peer-gateway
interface Vlan10
  no shutdown
  vrf member vpna
  no ip redirects
  ip address 10.18.1.254/24
  no ipv6 redirects
interface Vlan20
  no shutdown
  vrf member vpna
  ip address 10.18.2.254/24
interface Vlan101
  no shutdown
  vrf member vpna
  ip forward
  vpc 1
  switchport trunk allowed vlan 20
  vpc 2
  vpc peer-link
router ospf 100
  router-id 11.1.1.1
  no switchport
  ip address 172.17.5.2/30
  ip pim sparse-mode
  no shutdown
  no switchport
  ip address 172.17.6.2/30
  ip pim sparse-mode
  no shutdown
  no switchport
  vrf member heart
  no shutdown
interface loopback0
  ip address 11.1.1.1/32
  ip pim sparse-mode
interface loopback1
  ip address 11.1.2.1/32
  ip address 10.1.1.1/32 secondary
  ip pim sparse-mode
interface nve1
  no shutdown
  member vni 10
    suppress-arp
  member vni 20
    suppress-arp
router bgp 100
  template peer spine
    bfd multihop interval 250 min_rx 250 multiplier 3
    remote-as 100
  neighbor 22.1.1.1
    inherit peer spine
  neighbor 22.1.1.2
    inherit peer spine
  vrf vpna
(9)Cisco-SL02
hostname Cisco-SL02
cfs eth distribute
nv overlay evpn
feature ospf
feature bgp
feature pim
feature lacp
feature vpc
feature lldp
feature bfd
feature nv overlay
vlan 1,10,20,101
vlan 10
  vn-segment 10
vlan 20
  vn-segment 20
vlan 101
  vn-segment 101
evpn
  vni 10 l2
    rd auto
  vni 20 l2
    rd auto
vrf context heart
vrf context vpna
  vni 101
  rd auto
vpc domain 100
  peer-switch
  role priority 100
  system-priority 100
  peer-gateway
interface Vlan10
  no shutdown
  vrf member vpna
  no ip redirects
  no ipv6 redirects
interface Vlan20
  no shutdown
  vrf member vpna
interface Vlan101
  no shutdown
  vrf member vpna
  ip forward
  vpc 1
  vpc 2
  vpc peer-link
router ospf 100
  router-id 11.1.1.2
  no switchport
  ip address 172.17.7.2/30
  ip pim sparse-mode
  no shutdown
  no switchport
  ip address 172.17.8.2/30
  ip pim sparse-mode
  no shutdown
  no switchport
  vrf member heart
  no shutdown
interface loopback0
  ip address 11.1.1.2/32
  ip pim sparse-mode
interface loopback1
  ip address 11.1.2.2/32
  ip pim sparse-mode
interface nve1
  no shutdown
  member vni 10
    suppress-arp
  member vni 20
    suppress-arp
router bgp 100
  template peer spine
    remote-as 100
  neighbor 22.1.1.1
    inherit peer spine
  neighbor 22.1.1.2
    inherit peer spine
  vrf vpna
3、实验结果
(1)SP与leaf的ospf、pim、bgp evpn邻居正常建立
(2)server leaf、border leaf的vpc状态正常,其中BL对接的2台FW采用镜像模式,所以有一个聚合组会处于down状态
(3)Server leaf和Border leaf的nve隧道正常建立
(4)Server leaf可以学习到Border leaf引入的静态路由
(4)Border leaf可以学习到server leaf发布的主机路由10.18.1.10/32、10.18.2.10/32,并通过ospf传递给PE
(5)PC1和PC2均可以ping通PE01的环回口,并且tracert路径符合预期
发表于 2026-10-10 14:10:57 | 显示全部楼层
<p>交换机是用的N9K吗?</p>
