查看: 1257|回复: 4
Cisco ISE无法启动问题
有大神可以帮忙看看吗?感谢!
[  194.435658] dracut-initqueue[357]: Warning: dracut-initqueue timeout - starting timeout scripts
[  194.435780] dracut-initqueue[357]: Warning: Could not boot.
         Starting Setup Virtual Console...
[  OK  ] Started Setup Virtual Console.
         Starting Dracut Emergency Shell...
Warning: /dev/disk/by-uuid/8b84fe70-a279-4a0c-8de8-3079754723b3 does not exist
Generating "/run/initramfs/rdsosreport.txt"
Entering emergency mode. Exit the shell to continue.
Type "journalctl" to view system logs.
You might want to save "/run/initramfs/rdsosreport.txt" to a USB stick or /boot
after mounting them and attach it to a bug report.
dracut:/#
 楼主| 发表于 2024-12-23 16:11:17 | 显示全部楼层
镜像是ise-3.3.0-430.SPA, CPU4 内存8G
发表于 2024-12-24 08:22:28 | 显示全部楼层
4核16g以上资源试试,4核8g不够
发表于 2024-12-27 15:56:05 | 显示全部楼层
哈哈   牛啊
 楼主| 发表于 2024-12-27 20:54:57 | 显示全部楼层
hbugs001 发表于 2024-12-24 08:22
4核16g以上资源试试,4核8g不够
分了20G给ISE也开不动,直接在VMwares上自己装一台了。
