查看: 2513|回复: 2
思科 20190423IOU报错—%AMDP2_FE-6-EXCESSCOLL
思科IOU报错-----%AMDP2_FE-6-EXCESSCOLL-------跪求解法,狂包如下问题,现象:
思科模拟器版本:Cisco IOS Software, Linux Software (I86BI_LINUXL2-ADVENTERPRISEK9-M), Version 15.2(CML_NIGHTLY_20190423)FLO_DSGS7, EARLY DEPLOYMENT DEVELOPMENT BUILD, synced to  V152_6_0_81_E
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Tue 23-Apr-19 02:38 by mmen
*Mar  6 20:26:35.325: %PLATFORM-2-SIGNATURE_FAILED: Image '/i86bi_linux_l2-adventerprisek9-ms.SSA.high_iron_20190423.bin' failed code signing checks, error 'Failure in opening the file'. Ethernet switching has been disabled to protect against attack.
*Mar  6 20:26:35.893: %LINK-3-UPDOWN: Interface Ethernet0/0, changed state to up
*Mar  6 20:26:35.914: %LINK-3-UPDOWN: Interface Ethernet0/1, changed state to up
*Mar  6 20:26:35.944: %LINK-3-UPDOWN: Interface Ethernet0/2, changed state to up
*Mar  6 20:26:35.969: %LINK-3-UPDOWN: Interface Ethernet0/3, changed state to up
*Mar  6 20:26:36.319: %AMDP2_FE-6-EXCESSCOLL: Ethernet0/3 TDR=0, TRC=0
*Mar  6 20:26:36.899: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0, changed state to up
*Mar  6 20:26:36.914: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1, changed state to up
*Mar  6 20:26:36.949: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/2, changed state to up
*Mar  6 20:26:36.969: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/3, changed state to up
交换机开机无连接 任何设备疯狂弹日志,这是iol模拟器镜像的bug吗,真的很烦!
*Mar  6 20:27:07.358: %AMDP2_FE-6-EXCESSCOLL: Ethernet0/0 TDR=0, TRC=0
*Mar  6 20:27:37.429: %AMDP2_FE-6-EXCESSCOLL: Ethernet0/0 TDR=0, TRC=0
这方面的知识太复杂了。搜索开了一下“大概就是冲突数量太多,接口发送数据包遭遇太多了冲突,接口失败
*Oct 20 14:02:18.535: %AMDP2_FE-6-EXCESSCOLL: Ethernet0/0 TDR=0, TRC=0
  跪求解法求大神破解
发表于 2023-3-7 07:42:04 | 显示全部楼层
回帖奖励 +1 EML币
请使用最新版本eve,并且更换镜像版本后必须wipe设备再开机
 楼主| 发表于 2023-3-7 11:30:24 | 显示全部楼层
最新的是EVE-NG5.1吗 。社区懒人版4.0以上可以吗。使用shutdown命令可以消除吗
看老师的录屏新版本没有问题,2.0.3-60之前的老版本。 用 2018 和2019的L2镜像就会有问题 老是弹日志%AMDP2_FE-6-EXCESSCOLL: Ethernet0/0 TDR=0, TRC=0
发表于 2023-3-7 16:39:13 | 显示全部楼层
看老师的录屏新版本没有问 ...
请使用最新版本eve,2.0.3-95之前eve都会有你说这个问题!
