查看: 7499|回复: 6
EVE-NG修改Web默认端口号
不要修改原来80端口,只需要新增端口就行,以下可以忽略,请看二楼
修改web默认端口号:
具体把80 修改成 你想要的端口号,如:3211
1、修改/etc/apache2/port.conf
2、修改/etc/apache2/sites-available/000-default.conf
3、修改/etc/apache2/sites-available/unetlab.conf
4、/etc/init.d/apache2 restart
发表于 2019-10-3 08:03:03 | 显示全部楼层
80必须运行,只能新增端口
etc/apache2/ports.conf
etc/apache2/sites-enabled/unetlab.conf
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
ServerName eve-ng-com.example.com
<IfModule mod_rewrite.c>
        # Logging disabled by default
        # LogLevel mod_rewrite.c:trace2
</IfModule>
<Directory /opt/unetlab/html/>
        Options FollowSymLinks
        AllowOverride All
        Require all granted
</Directory>
<Directory /opt/unetlab/data/Exports/>
        Options FollowSymLinks Indexes
        AllowOverride All
        Require all granted
</Directory>
<Directory /opt/unetlab/data/Logs/>
        AllowOverride All
        Require all granted
</Directory>
<VirtualHost *:80>
        ServerAdmin webmaster@unl01.example.com
        DocumentRoot /opt/unetlab/html
        ErrorLog /opt/unetlab/data/Logs/error.txt
        CustomLog /opt/unetlab/data/Logs/access.txt combined
        Alias /Exports /opt/unetlab/data/Exports
        Alias /Logs /opt/unetlab/data/Logs
        <Location /html5/>
                Order allow,deny
                Allow from all
                ProxyPass http://127.0.0.1:8080/guacamole/ flushpackets=on
                ProxyPassReverse http://127.0.0.1:8080/guacamole/
        </Location>
        <Location /html5/websocket-tunnel>
                Order allow,deny
                Allow from all
                ProxyPass ws://127.0.0.1:8080/guacamole/websocket-tunnel
                ProxyPassReverse ws://127.0.0.1:8080/guacamole/websocket-tunnel
        </Location>
</VirtualHost>
<VirtualHost *:8000>
        <Location /html5/>
                Order allow,deny
                Allow from all
        </Location>
                Order allow,deny
                Allow from all
        </Location>
</VirtualHost>
另外,如需要更改证书可以参考以下
nano /etc/apache2/sites-enabled/eveng-ssl.conf
change:
        SSLCertificateFile    /etc/letsencrypt/live/eve-pro.alora.lv/fullchain.pem
        SSLCertificateKeyFile /etc/letsencrypt/live/eve-pro.alora.lv/privkey.pem
to
        SSLCertificateFile    /etc/ssl/certs/apache-selfsigned.crt
        SSLCertificateKeyFile /etc/ssl/private/apache-selfsigned.key
Restart apache2
systemctl stop apache2
systemctl start apache2
发表于 2019-12-23 18:23:54 | 显示全部楼层
感谢分享,学习了
发表于 2020-1-23 10:18:15 | 显示全部楼层
谢谢,记录了
9万
发表于 2020-5-1 10:55:47 | 显示全部楼层
厉害!学习了
发表于 2021-10-9 17:17:10 | 显示全部楼层
学习了
发表于 2022-6-1 16:38:07 | 显示全部楼层
ports.conf文件里面也需要改么,我在unetlab.conf文件里面增加了还是不行
