查看: 3428|回复: 4
Juniper VMX 创建双RE 多FPC
最多只允许2个RE。理论上最多可以用12个FPC(0-11),每个FPC最多可以用100个接口(0-99)。
示例连线
[attach]1445[/attach]
购买主题 已有 37 人购买  本主题需向作者支付 2 EML币 才能浏览
发表于 2021-12-26 23:22:50 | 显示全部楼层
感谢楼主无私分享
发表于 2022-1-7 19:58:29 | 显示全部楼层
楼主您好,谢谢你的步骤,我按照你的步骤做成功了,两个RE 两个FPC,但是我去检查backup RE能否去切换时提示说不行。你尝试过切换吗?
root@vMX-Dual-RE> request chassis routing-engine master switch check
warning: Traffic will be interrupted while the PFE is re-initialized
Standby Routing Engine is not ready for graceful switchover.
root@vMX-Dual-RE> show chassis routing-engine
Routing Engine status:
  Slot 0:
    Current state                  Master
    Election priority              Master (default)
    DRAM                      1994 MB (2048 MB installed)
    Memory utilization          45 percent
    5 sec CPU utilization:
      User                       0 percent
      Background                 0 percent
      Kernel                     2 percent
      Interrupt                  0 percent
      Idle                      98 percent
    1 min CPU utilization:
      User                       1 percent
      Kernel                     1 percent
      Interrupt                  0 percent
      Idle                      98 percent
    5 min CPU utilization:
      User                       1 percent
      Kernel                     1 percent
      Interrupt                  0 percent
      Idle                      98 percent
    15 min CPU utilization:
      User                       1 percent
      Kernel                     1 percent
      Interrupt                  0 percent
      Idle                      87 percent
    Model                          RE-VMX
    Start time                     2022-01-07 11:22:44 UTC
    Uptime                         35 minutes, 25 seconds
    Last reboot reason             Router rebooted after a normal shutdown.
    Load averages:                 1 minute   5 minute  15 minute
                                       0.45       0.51       0.43
  Slot 1:
    Current state                  Backup
    Election priority              Backup (default)
    Memory utilization          27 percent
      User                       0 percent
      Kernel                     1 percent
      Interrupt                  0 percent
      Idle                      99 percent
    Model                          RE-VMX
    Start time                     2022-01-07 11:22:46 UTC
    Uptime                         35 minutes, 17 seconds
                                       0.31       0.34       0.33
root@vMX-Dual-RE>
发表于 2022-1-7 21:47:21 | 显示全部楼层
帝吧大狸子 发表于 2022-1-7 19:58
楼主您好,谢谢你的步骤,我按照你的步骤做成功了,两个RE 两个FPC,但是我去检查backup RE能否去切换时提 ...
问题解决 少配置了这个
root@vMX-Dual-RE# set chassis redundancy graceful-switchover
 楼主| 发表于 2022-3-14 12:35:28 | 显示全部楼层
帝吧大狸子 发表于 2022-1-7 21:47
问题解决 少配置了这个
1.该命令是平稳切换,切换时不会影响业务。
2.之前无法切换应该是刚刚开机2个RE之间各类协议配置还在同步,等几分钟就行。
