查看: 2999|回复: 2
求助!Nokia 7750SR启动不起来……
如题,使用的是15.0.R3版本,启动到这里就卡住了,下面没有反应……
Press any key to stop auto-boot...
auto-booting...
boot device          : ata=0,2
unit number          : 0
processor number     : 0
host name            : 0.0.0.0
file name            : cf3:/timos/i386-boot.tim
ftp password (pw)    : *****
flags (f)            : 0x8
target name (tn)     : VSR-I
startup script (s)   : pl=1
other (o)            : vsr-c#vsr_cpm,vsr_iom|158|0|0|0
sysVmBootStringModify: modified boot file to: cf3:/timos/i386-iom.tim
Booting from ata=0,2:cf3:/timos/i386-iom.tim
Loading cf3:/timos/i386-iom.tim ...
Version I-15.0.R3, Thu May 25 15:36:31 PDT 2017 by builder in /builds/rel15.0/150B/R3/panos/main
text6418498816-->58985560) + data6426491072-->48063136)
Starting at 0x133000...
(s) boot params: pl=1; setting TgtPf to 0x00000001
Running in a KVM/QEMU virtual machine
Enabled core count: 2
ACPI: found 2 cores, 2 enabled
ACPI: ctrl-x only supported with PXE boot. (version >= 3)
ACPI: _S5_ error: SLP_TYPa does not contain values between 0x00 and 0x07 (it is 0x0)
ACPI: Not enabled.
Total Memory: 2047MB  Chassis Type: 0x2  Core Freq: 2309.642 MHz
TiMOS-I-15.0.R3 iom/x86_64 Nokia 7750 SR Copyright (c) 2000-2017 Nokia.
All rights reserved. All use subject to applicable license agreements.
Built on Thu May 25 15:21:13 PDT 2017 by builder in /builds/rel15.0/150B/R3/panos/main
   ___                    ___           ___           ___
  /\  \                  /\__\         /\  \         /\  \
  \:\  \        ___     /::|  |       /::\  \       /::\  \
   \:\  \      /\__\   /:|:|  |      /:/\:\  \     /:/\:\  \
   /::\  \    _\/__/  /:/|:|__|__   /:/  \:\  \   _\:\~\:\  \
  /:/\:\__\  /\__\   /:/ |::::\__\ /:/__/ \:\__\ /\ \:\ \:\__\
/:/  \/__/ /:/  /   \/__/~~/:/  / \:\  \ /:/  / \:\ \:\ \/__/
/:/  /     /:/  /          /:/  /   \:\  /:/  /   \:\ \:\__\
\/__/      \/__/          /:/  /     \:\/:/  /     \:\/:/  /
                         \/__/         \/__/         \/__/
Running 64 bit architecture
Initializing VMM
  Virtual address sharing is disabled
Time from clock is WED NOV 24 13:24:04 2021 UTC
Looking for boot parameters.
SMP: 2 cores available
发表于 2021-11-24 22:40:31 | 显示全部楼层
 楼主| 发表于 2021-11-25 21:15:02 | 显示全部楼层
hbugs001 发表于 2021-11-24 22:40
先参考这个检查下:
https://www.eve-ng.net/index.php/documentation/howtos/howto-add-nokia-vsr/ ...
感谢大佬帮助,看了这个,里面提到要添加License,这个License要去什么地方获取呢?
