查看: 3676|回复: 1
【直播录屏】4.0.1-62 PRO更新
455
录屏地址:
视频演示中遇到的docker创建web服务器问题使用以下正确预配,cookbook里边不能直接复制,需要改动格式
  1. # Set ip address and Default route
  2. ip addr add 10.1.1.100/24 dev eth0 || true
  3. ip route add default via 10.1.1.254 || true
  4. # Set DNS server
  5. cat > /etc/resolv.conf << EOF
  6. nameserver 8.8.8.8
  7. EOF
  8. # Create a Default web page
  9. # Use 'EOF' do avoid variable from expanding
  10. # Delete default index page
  11. rm /var/www/html/index.html || true
  12. # Create a Default web page
  13. # Use 'EOF' do avoid variable from expanding
  14. cat > /var/www/html/index.php << 'EOF'
  15. <center>
  16. <?php
  17. echo gethostname();
  18. ?>
  19. <hr>
  20. <img  width="596" height="239"  src="data:image/png;base64,---imagecode ommittedg==">
  21. <hr>
  22. <?php
  23. //whether ip is from share internet
  24. if (!empty($_SERVER['HTTP_CLIENT_IP']))
  25.   {
  26.     $ip_address = $_SERVER['HTTP_CLIENT_IP'];
  27.   }
  28. //whether ip is from proxy
  29. elseif (!empty($_SERVER['HTTP_X_FORWARDED_FOR']))
  30.   {
  31.     $ip_address = $_SERVER['HTTP_X_FORWARDED_FOR'];
  32.   }
  33. //whether ip is from remote address
  34. else
  35.   {
  36.     $ip_address = $_SERVER['REMOTE_ADDR'];
  37.   }
  38. echo 'Client Address:'.$ip_address;
  39. ?>
  40. </center>
  41. EOF
发表于 2021-10-24 19:55:59 | 显示全部楼层
谢谢分享,好好学习
