查看: 3852|回复: 4
7750最新镜像无法启动
7750最新镜像无法启动,卡在HALT SYSTEM
发表于 2021-7-11 01:55:37 | 显示全部楼层
等个回复
发表于 2021-7-14 06:36:02 | 显示全部楼层
没遇到过,坐等大佬解答
发表于 2021-7-14 09:26:35 | 显示全部楼层
7750是什么个东东
发表于 2021-11-24 21:26:48 | 显示全部楼层
我也启动不了,卡在这里了:
Running in a KVM/QEMU virtual machine
Enabled core count: 2
ACPI: found 2 cores, 2 enabled
ACPI: ctrl-x only supported with PXE boot. (version >= 3)
ACPI: _S5_ error: SLP_TYPa does not contain values between 0x00 and 0x07 (it is 0x0)
ACPI: Not enabled.
Total Memory: 2047MB  Chassis Type: 0x2  Core Freq: 2309.642 MHz
TiMOS-I-15.0.R3 iom/x86_64 Nokia 7750 SR Copyright (c) 2000-2017 Nokia.
All rights reserved. All use subject to applicable license agreements.
Built on Thu May 25 15:21:13 PDT 2017 by builder in /builds/rel15.0/150B/R3/panos/main
   ___                    ___           ___           ___
  /\  \                  /\__\         /\  \         /\  \
  \:\  \        ___     /::|  |       /::\  \       /::\  \
   \:\  \      /\__\   /:|:|  |      /:/\:\  \     /:/\:\  \
   /::\  \    _\/__/  /:/|:|__|__   /:/  \:\  \   _\:\~\:\  \
  /:/\:\__\  /\__\   /:/ |::::\__\ /:/__/ \:\__\ /\ \:\ \:\__\
/:/  \/__/ /:/  /   \/__/~~/:/  / \:\  \ /:/  / \:\ \:\ \/__/
/:/  /     /:/  /          /:/  /   \:\  /:/  /   \:\ \:\__\
\/__/      \/__/          /:/  /     \:\/:/  /     \:\/:/  /
                         \/__/         \/__/         \/__/
Running 64 bit architecture
Initializing VMM
  Virtual address sharing is disabled
Time from clock is WED NOV 24 13:24:04 2021 UTC
Looking for boot parameters.
SMP: 2 cores available
