查看: 14089|回复: 10
vyos使用指南
1、镜像用户名 :vyos 密码:vyos
2、vyos相关wiki :https://wiki.vyos.net/wiki/User_Guide
3、支持功能如下:
VLANs:
     802.1q and QinQ
Static and dynamic routing:
     BGP for IPv4 and IPv6, OSPFv2, RIP, RIPng, policy-based routing, equal cost multi-path
Firewall:
     Firewall rulesets for IPv4 and IPv6 traffic you can assign to interfaces, zone-based firewall, address/network/port groups for IPv4 firewalls
Tunnel interfaces:
     PPPoE, GRE, IPIP, SIT, static L2TPv3, VXLAN
VPN:
    Site-to-site IPsec for IPv4 and IPv6, L2TP/IPsec server, PPTP server, OpenVPN for site-to-site and remote access
NAT:
    Source NAT, port forwards, one to one, one to many, and many to many translations
DHCP:
    DHCP and DHCPv6 server and relay
Redundancy:
    VRRP, connection table synchronization
4、登录vyos后界面如下:会话以$为提示符
    vyos@vyos:~$ s[tab]
    set   show
    vyos@vyos:~$
5、支持tab键补齐
vyos@vyos:~$ show [tab]
Possible completions:
  arp           Show Address Resolution Protocol (ARP) information
  bridge        Show bridging information
  cluster       Show clustering information
  configuration Show running configuration
  conntrack     Show conntrack entries in the conntrack table
  conntrack-sync
                Show connection syncing information
  date          Show system date and time
  dhcp          Show Dynamic Host Configuration Protocol (DHCP) information
  dhcpv6        Show status related to DHCPv6
  disk          Show status of disk device
  dns           Show Domain Name Server (DNS) information
  file          Show files for a particular image
  firewall      Show firewall information
  flow-accounting
                Show flow accounting statistics
  hardware      Show system hardware details
  history       show command history
  host          Show host information
  incoming      Show ethernet input-policy information
: q
vyos@vyos:~$
6、进入配置模式:
vyos@vyos:~$ configure
[edit]
vyos@vyos:~#
7、修改主机名
[edit]
vyos@vyos:~#set system host-name host1
[edit]
vyos@vyos:~#
提交配置
vyos@vyos:~#commit
保存配置
vyos@vyos:~#save
退出配置模式
vyos@vyos:~#exit
重启系统后生效
vyos@vyos:~#reboot
8、配置网络接口
set interfaces ethernet eth0 address dhcp
set interfaces ethernet eth0 description 'OUTSIDE'
set interfaces ethernet eth1 address '192.168.0.1/24'
set interfaces ethernet eth1 description 'INSIDE'
9、配置ssh远程端口
set service ssh port '22'
10、配置源地址NAT
set nat source rule 100 outbound-interface 'eth0'
set nat source rule 100 source address '192.168.0.0/24'
set nat source rule 100 translation address masquerade
11、配置DHCP 服务器
set service dhcp-server disabled 'false'
set service dhcp-server shared-network-name LAN subnet 192.168.0.0/24 default-router '192.168.0.1'
set service dhcp-server shared-network-name LAN subnet 192.168.0.0/24 dns-server '192.168.0.1'
set service dhcp-server shared-network-name LAN subnet 192.168.0.0/24 domain-name 'internal-network'
set service dhcp-server shared-network-name LAN subnet 192.168.0.0/24 lease '86400'
set service dhcp-server shared-network-name LAN subnet 192.168.0.0/24 start 192.168.0.9 stop '192.168.0.254'
12、配置DNS转发
set service dns forwarding cache-size '0'
set service dns forwarding listen-on 'eth1'
set service dns forwarding name-server '8.8.8.8'
set service dns forwarding name-server '8.8.4.4'
13、配置防火墙规则
set firewall name OUTSIDE-IN default-action 'drop'
set firewall name OUTSIDE-IN rule 10 action 'accept'
set firewall name OUTSIDE-IN rule 10 state established 'enable'
set firewall name OUTSIDE-IN rule 10 state related 'enable'
set firewall name OUTSIDE-LOCAL default-action 'drop'
set firewall name OUTSIDE-LOCAL rule 10 action 'accept'
set firewall name OUTSIDE-LOCAL rule 10 state established 'enable'
set firewall name OUTSIDE-LOCAL rule 10 state related 'enable'
set firewall name OUTSIDE-LOCAL rule 20 action 'accept'
set firewall name OUTSIDE-LOCAL rule 20 icmp type-name 'echo-request'
set firewall name OUTSIDE-LOCAL rule 20 protocol 'icmp'
set firewall name OUTSIDE-LOCAL rule 20 state new 'enable'
set firewall name OUTSIDE-LOCAL rule 30 action 'drop'
set firewall name OUTSIDE-LOCAL rule 30 destination port '22'
set firewall name OUTSIDE-LOCAL rule 30 protocol 'tcp'
set firewall name OUTSIDE-LOCAL rule 30 recent count '4'
set firewall name OUTSIDE-LOCAL rule 30 recent time '60'
set firewall name OUTSIDE-LOCAL rule 30 state new 'enable'
set firewall name OUTSIDE-LOCAL rule 31 action 'accept'
set firewall name OUTSIDE-LOCAL rule 31 destination port '22'
set firewall name OUTSIDE-LOCAL rule 31 protocol 'tcp'
set firewall name OUTSIDE-LOCAL rule 31 state new 'enable'
14、生效防火墙规则
set interfaces ethernet eth0 firewall in name 'OUTSIDE-IN'
set interfaces ethernet eth0 firewall local name 'OUTSIDE-LOCAL'
15、保存配置
vyos@vyos# commit
vyos@vyos# save
Saving configuration to '/config/config.boot'...
Done
vyos@vyos# exit
vyos@vyos$
16、查看配置
vyos@vyos:~$  show configuration
interfaces {
    ethernet eth0 {
        address dhcp
        hw-id 00:0c:29:44:3b:0f
    loopback lo {
service {
    ssh {
        port 22
system {
    config-management {
        commit-revisions 20
    console {
        device ttyS0 {
            speed 9600
    login {
        user vyos {
            authentication {
                encrypted-password ****************
            level admin
    ntp {
        server 0.pool.ntp.org {
        server 1.pool.ntp.org {
        server 2.pool.ntp.org {
    package {
        repository community {
            components main
            distribution hydrogen
            url http://packages.vyos.net/vyos
    syslog {
        global {
            facility all {
                level notice
            facility protocols {
                level debug
vyos@vyos:~$
17、查看接口配置信息
[edit]
vyos@vyos# show interfaces
ethernet eth0 {
     address dhcp
loopback lo {
[edit]
vyos@vyos# set interfaces ethernet eth0 description 'OUTSIDE'
[edit]
ethernet eth0 {
     address dhcp
+    description OUTSIDE
loopback lo {
[edit]
18、查看接口
vyos@vyos:~$ show interfaces
Codes: S - State, L - Link, u - Up, D - Down, A - Admin Down
Interface        IP Address                        S/L  Description
eth0             172.16.51.129/24                  u/u  OUTSIDE
eth1             192.168.0.1/24                    u/u  INSIDE
lo               127.0.0.1/8                       u/u
                 ::1/128
vyos@vyos:~$
19、查看接口网卡信息
vyos@vyos:~$ show interfaces ethernet eth0
eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP qlen 1000
    link/ether 00:0c:29:44:3b:0f brd ff:ff:ff:ff:ff:ff
    inet 172.16.51.129/24 brd 172.16.51.255 scope global eth0
    inet6 fe80::20c:29ff:fe44:3b0f/64 scope link
       valid_lft forever preferred_lft forever
    Description: OUTSIDE
    RX:  bytes    packets     errors    dropped    overrun      mcast
        274397       3064          0          0          0          0
    TX:  bytes    packets     errors    dropped    carrier collisions
        257276       1890          0          0          0          0
    vyos@vyos:~$
20、配置接口描述和接口参数
set interfaces ethernet eth0 address 'dhcp'
21、配置以太网接口
set interfaces ethernet eth1 duplex 'auto'
set interfaces ethernet eth1 speed 'auto'
22、配置vlan
set interfaces ethernet eth1 vif 100 description 'VLAN 100'
set interfaces ethernet eth1 vif 100 address '192.168.100.1/24'
查看配置
   ethernet eth1 {
       address 192.168.0.1/24
       description INSIDE
       duplex auto
       hw-id 00:0c:29:44:3b:19
       smp_affinity auto
       speed auto
       vif 100 {
           address 192.168.100.1/24
           description "VLAN 100"
eth1.100         192.168.100.1/24                  u/u  VLAN 100
lo               127.0.0.1/8                       u/u
                 ::1/128
vyos@vyos:~$
23、配置桥口绑定
set interfaces bridge 'br100'
set interfaces ethernet eth1 vif 100 bridge-group bridge br100
   配置桥IP地址
set interfaces bridge br100 address '192.168.100.1/24'
   配置桥接模式开启STP
   set interfaces bridge br100 stp true
   查看桥信息
   vyos@vyos:~$ show bridge
bridge name     bridge id               STP enabled     interfaces
br100           0000.000c29443b19       yes             eth1.100
vyos@vyos:~$
vyos@vyos:~$ show bridge br100 spanning-tree
br100
bridge id              0000.000c29443b19
designated root        0000.000c29443b19
root port                 0                    path cost                  0
max age                  20.00                 bridge max age            20.00
hello time                2.00                 bridge hello time          2.00
forward delay            15.00                 bridge forward delay      15.00
ageing time             300.00
hello timer               0.47                 tcn timer                  0.00
topology change timer     0.00                 gc timer                  64.63
flags
eth1.100 (1)
port id                8001                    state                forwarding
designated root        0000.000c29443b19       path cost                  4
designated bridge      0000.000c29443b19       message age timer          0.00
designated port        8001                    forward delay timer        0.00
designated cost           0                    hold timer                 0.00
flags
vyos@vyos:~$
vyos@vyos:~$ show bridge br100 macs
port no mac addr                is local?       ageing timer
  1     00:0c:29:44:3b:19       yes                0.00
vyos@vyos:~$
24、配置端口绑定
set interfaces bonding bond0 description 'my-sw1 int 23 and 24'
vyos@vyos# set interfaces bonding bond0 hash-policy
  layer2       use MAC addresses to generate the hash (802.3ad)
  layer2+3     combine MAC address and IP address to make hash
  layer3+4     combine IP address and port to make hash
  set interfaces bonding bond0 hash-policy 'layer2'
  set interfaces bonding bond0 mode '802.3ad'
  配置绑定模式
  vyos@vyos# set interfaces bonding bond0 mode
  802.3ad      IEEE 802.3ad Dynamic link aggregation (Default)
  active-backup
               Fault tolerant: only one slave in the bond is active
  broadcast    Fault tolerant: transmits everything on all slave interfaces
  round-robin  Load balance: transmit packets in sequential order
  transmit-load-balance
               Load balance: adapts based on transmit load and speed
  adaptive-load-balance
               Load balance: adapts based on transmit and receive plus ARP
  xor-hash     Load balance: distribute based on MAC address
  绑定接口道bond0
  set interfaces ethernet eth0 bond-group 'bond0'
  set interfaces ethernet eth0 description 'member of bond0'
  set interfaces ethernet eth1 bond-group 'bond0'
  set interfaces ethernet eth1 description 'member of bond0'
  查看绑定端口信息
  vyos@vyos# run sh interfaces bonding
bond0            -                                 u/u  my-sw1 int 23 and 24
bond0.10         192.168.0.1/24                    u/u  office-net
bond0.100        10.10.10.1/24                     u/u  management-net
25、配置隧道接口
set interfaces vti vti0 address 192.168.2.249/30
vyos@vyos# show interfaces vti
vti vti0 {
    description "Description"
26、配置路由
    配置静态路由
    set protocols static route 0.0.0.0/0 next-hop 203.0.113.1 distance '1'
    查看配置信息
    static {
    route 0.0.0.0/0 {
        next-hop 203.0.113.1 {
            distance 1
配置黑洞路由
set protocols static route 10.0.0.0/8 blackhole distance '254'
set protocols static route 172.16.0.0/12 blackhole distance '254'
set protocols static route 192.168.0.0/16 blackhole distance '254'
route 10.0.0.0/8 {
    blackhole {
        distance 254
route 172.16.0.0/12 {
    blackhole {
        distance 254
route 192.168.0.0/16 {
    blackhole {
        distance 254
26、配置RIP
节点1
set interfaces loopback address 1.1.1.1/32
set protocols rip network 192.168.0.0/24
set protocols rip redistribute connected
节点2
set interfaces loopback address 2.2.2.2/32
27、配置OSPF
IPV4
节点1
set interfaces loopback lo address 1.1.1.1/32
set protocols ospf area 0 network 192.168.0.0/24
set protocols ospf default-information originate always
set protocols ospf default-information originate metric 10
set protocols ospf default-information originate metric-type 2
set protocols ospf log-adjacency-changes
set protocols ospf parameters router-id 1.1.1.1
set protocols ospf redistribute connected metric-type 2
set protocols ospf redistribute connected route-map CONNECT
set policy route-map CONNECT rule 10 action permit
set policy route-map CONNECT rule 10 match interface lo
节点2
set interfaces loopback lo address 2.2.2.2/32
set protocols ospf parameters router-id 2.2.2.2
IPV6
节点1
set protocols ospfv3 area 0.0.0.0 interface eth1
set protocols ospfv3 area 0.0.0.0 range 2001:db8:1::/64
set protocols ospfv3 parameters router-id 192.168.1.1
set protocols ospfv3 redistribute connected
节点2
set protocols ospfv3 area 0.0.0.0 range 2001:db8:2::/64
set protocols ospfv3 parameters router-id 192.168.2.1
28、配置BGP
IPV4(eBGP)
节点1
set protocols bgp 65536 neighbor 192.168.0.2 ebgp-multihop '2'
set protocols bgp 65536 neighbor 192.168.0.2 remote-as '65537'
set protocols bgp 65536 neighbor 192.168.0.2 update-source ‘192.168.0.1
set protocols bgp 65536 network '1.0.0.0/16'
set protocols bgp 65536 parameters router-id ‘192.168.0.1
节点2
set protocols bgp 65537 neighbor 192.168.0.1 ebgp-multihop '2'
set protocols bgp 65537 neighbor 192.168.0.1 remote-as '65536’
set protocols bgp 65537 neighbor 192.168.0.1 update-source ‘192.168.0.2
set protocols bgp 65537 network 2.0.0.0/16'
set protocols bgp 65537 parameters router-id ‘192.168.0.2
配置黑洞路由
节点1
set protocols static route 1.0.0.0/16 blackhole distance '254'
节点2
set protocols static route 2.0.0.0/16 blackhole distance '254'
IPv6
节点一
set protocols bgp 65536 neighbor 2a00:100::2 ebgp-multihop '2'
set protocols bgp 65536 neighbor 2a00:100::2 remote-as '65537'
set protocols bgp 65536 neighbor 2a00:100::2 update-source '2a00:100::1'
set protocols bgp 65536 neighbor 2a00:100::2 address-family ipv6-unicast
set protocols bgp 65536 address-family ipv6-unicast network '2a00:100:1::/48'
set protocols bgp 65536 parameters router-id '1.1.1.1'
节点二
set protocols bgp 65537 neighbor 2a00:100::1 ebgp-multihop '2'
set protocols bgp 65537 neighbor 2a00:100::1 remote-as '65536'
set protocols bgp 65537 neighbor 2a00:100::1 update-source '2a00:100::2'
set protocols bgp 65536 neighbor 2a00:100::1 address-family ipv6-unicast
set protocols bgp 65537 address-family ipv6-unicast network '2a00:100:2::/48'
set protocols bgp 65537 parameters router-id '1.1.1.2'
配置黑洞路由
节点1
set protocols static route6 2a001:100:1::/48 blackhole distance '254'
节点2
set protocols static route6 2a00:100:2::/48 blackhole distance '254'
29、配置路由过滤
路由过滤可以使用路由映射应用
节点1
set policy prefix-list AS65537-IN rule 10 action 'permit'
set policy prefix-list AS65537-IN rule 10 prefix '2.0.0.0/16'
set policy prefix-list AS65537-OUT rule 10 action 'deny'
set policy prefix-list AS65537-OUT rule 10 prefix '2.0.0.0/16'
set policy prefix-list6 AS65537-IN rule 10 action 'permit'
set policy prefix-list6 AS65537-IN rule 10 prefix '2a00:100:2::/48'
set policy prefix-list6 AS65537-OUT rule 10 action 'deny'
set policy prefix-list6 AS65537-OUT rule 10 prefix '2a00:100:2::/48'
set policy route-map AS65537-IN rule 10 action 'permit'
set policy route-map AS65537-IN rule 10 match ip address prefix-list 'AS65537-IN'
set policy route-map AS65537-IN rule 10 match ipv6 address prefix-list 'AS65537-IN'
set policy route-map AS65537-IN rule 20 action 'deny'
set policy route-map AS65537-OUT rule 10 action 'deny'
set policy route-map AS65537-OUT rule 10 match ip address prefix-list 'AS65537-OUT'
set policy route-map AS65537-OUT rule 10 match ipv6 address prefix-list 'AS65537-OUT'
set policy route-map AS65537-OUT rule 20 action 'permit'
set protocols bgp 65536 neighbor 2a00:100::2 route-map export 'AS65537-OUT'
set protocols bgp 65536 neighbor 2a00:100::2 route-map import 'AS65537-IN'
节点2
set policy prefix-list AS65536-IN rule 10 action 'permit'
set policy prefix-list AS65536-IN rule 10 prefix '1.0.0.0/16'
set policy prefix-list AS65536-OUT rule 10 action 'deny'
set policy prefix-list AS65536-OUT rule 10 prefix '1.0.0.0/16'
set policy prefix-list6 AS65536-IN rule 10 action 'permit'
set policy prefix-list6 AS65536-IN rule 10 prefix '2a00:100:1::/48'
set policy prefix-list6 AS65536-OUT rule 10 action 'deny'
set policy prefix-list6 AS65536-OUT rule 10 prefix '2a00:100:1::/48'
set policy route-map AS65536-IN rule 10 action 'permit'
set policy route-map AS65536-IN rule 10 match ip address prefix-list 'AS65536-IN'
set policy route-map AS65536-IN rule 10 match ipv6 address prefix-list 'AS65536-IN'
set policy route-map AS65536-IN rule 20 action 'deny'
set policy route-map AS65536-OUT rule 10 action 'deny'
set policy route-map AS65536-OUT rule 10 match ip address prefix-list 'AS65536-OUT'
set policy route-map AS65536-OUT rule 10 match ipv6 address prefix-list 'AS65536-OUT'
set policy route-map AS65536-OUT rule 20 action 'permit'
set protocols bgp 65537 neighbor 2a00:100::1 route-map export 'AS65536-OUT'
set protocols bgp 65537 neighbor 2a00:100::1 route-map import 'AS65536-IN'
30、配置策略路由
VyOS支持策略路由,允许将流量分配给不同的路由表。流量可以使用标准的5元组匹配(源地址,目的地址,协议,源端口,目的端口)进行匹配
以下示例将显示如何使用VyOS将Web流量重定向到外部透明代理
set policy route FILTER-WEB rule 1000 destination port 80
set policy route FILTER-WEB rule 1000 protocol tcp
set policy route FILTER-WEB rule 1000 set table 100
在这里我们创建了一个名为FILTER-WEB的路由策略,其中一条规则将路由表设置为匹配流量(TCP端口80)到表ID 100而不是默认路由表
这可以使用show ip route table 100操作命令来确认,最后,我们使用在LAN接口上应用策略路由到流量。
set interfaces ethernet eth1 policy route FILTER-WEB
31、防火墙规则
创建组
set firewall group network-group NET-INSIDE network 192.168.0.0/24
set firewall group network-group NET-INSIDE network 192.168.1.0/24
配置规则集合
set firewall name INSIDE-OUT default-action drop
set firewall name INSIDE-OUT rule 1010 action accept
set firewall name INSIDE-OUT rule 1010 state established enable
set firewall name INSIDE-OUT rule 1010 state related enable
set firewall name INSIDE-OUT rule 1020 action drop
set firewall name INSIDE-OUT rule 1020 state invalid enable
应用规则到接口
set interfaces ethernet eth1 firewall out name INSIDE-OUT
应用规则到zone
set zone-policy zone INSIDE from OUTSIDE firewall name INSIDE-OUT
32、配置NAT
配置源地址NAT
set nat source rule 100 translation address 'masquerade'
配置目的地址NAT
set nat destination rule 10 description 'Port Forward: HTTP to 192.168.0.100'
set nat destination rule 10 destination port '80'
set nat destination rule 10 inbound-interface 'eth0'
set nat destination rule 10 protocol 'tcp'
set nat destination rule 10 translation address '192.168.0.100'
配置1to1 NAT
set interfaces ethernet eth0 address '192.168.1.1/24'
set interfaces ethernet eth0 description 'Inside interface'
set interfaces ethernet eth1 address '1.2.3.4/24'
set interfaces ethernet eth1 description 'Outside interface'
set nat destination rule 2000 description '1-to-1 NAT example'
set nat destination rule 2000 destination address '1.2.3.4'
set nat destination rule 2000 inbound-interface 'eth1'
set nat destination rule 2000 translation address '192.168.1.10'
set nat source rule 2000 description '1-to-1 NAT example'
set nat source rule 2000 outbound-interface 'eth1'
set nat source rule 2000 source address '192.168.1.10'
set nat source rule 2000 translation address '1.2.3.4'
33、配置VPN
a)、配置OpenVPN 点对点模式
本地配置
set interfaces openvpn vtun1 mode site-to-site
set interfaces openvpn vtun1 protocol udp
set interfaces openvpn vtun1 persistent-tunnel
set interfaces openvpn vtun1 local-host '198.51.100.10'
set interfaces openvpn vtun1 local-port '1195'
set interfaces openvpn vtun1 remote-port '1195'
set interfaces openvpn vtun1 shared-secret-key-file '/config/auth/openvpn-1.key'
set interfaces openvpn vtun1 local-address '10.255.1.1'
set interfaces openvpn vtun1 remote-address '10.255.1.2'
远程配置
set interfaces openvpn vtun1 remote-host '198.51.100.10'
set interfaces openvpn vtun1 local-address '10.255.1.2'
set interfaces openvpn vtun1 remote-address '10.255.1.1'
vyos@vyos# set interfaces openvpn vtun1 encryption
  des          DES algorithm
  3des         DES algorithm with triple encryption
  bf128        Blowfish algorithm with 128-bit key
  bf256        Blowfish algorithm with 256-bit key
  aes128       AES algorithm with 128-bit key
  aes192       AES algorithm with 192-bit key
  aes256       AES algorithm with 256-bit key
  vyos@vyos# set interfaces openvpn vtun1 hash
  md5          MD5 algorithm
  sha1         SHA-1 algorithm
  sha256       SHA-256 algorithm
  sha512       SHA-512 algorithm
  配置本地通道
   set protocols static interface-route 10.1.0.0/16 next-hop-interface vtun1
  配置远程通道
   set protocols static interface-route 10.0.0.0/16 next-hop-interface vtun1
b)、配置L2TP over IPsec
c)、配置点对点IPsec
服务器端配置
set vpn ipsec esp-group office-srv-esp compression 'disable'
set vpn ipsec esp-group office-srv-esp lifetime '1800'
set vpn ipsec esp-group office-srv-esp mode 'tunnel'
set vpn ipsec esp-group office-srv-esp pfs 'enable'
set vpn ipsec esp-group office-srv-esp proposal 1 encryption 'aes256'
set vpn ipsec esp-group office-srv-esp proposal 1 hash 'sha1'
set vpn ipsec ike-group office-srv-ike ikev2-reauth 'no'
set vpn ipsec ike-group office-srv-ike key-exchange 'ikev1'
set vpn ipsec ike-group office-srv-ike lifetime '3600'
set vpn ipsec ike-group office-srv-ike proposal 1 encryption 'aes256'
set vpn ipsec ike-group office-srv-ike proposal 1 hash 'sha1'
set vpn ipsec ipsec-interfaces interface 'eth1'
set vpn ipsec site-to-site peer 2.2.2.2 authentication mode 'pre-shared-secret'
set vpn ipsec site-to-site peer 2.2.2.2 authentication pre-shared-secret 'SomePreSharedKey'
set vpn ipsec site-to-site peer 2.2.2.2 ike-group 'office-srv-ike'
set vpn ipsec site-to-site peer 2.2.2.2 local-address '1.1.1.1'
set vpn ipsec site-to-site peer 2.2.2.2 tunnel 0 allow-nat-networks 'disable'
set vpn ipsec site-to-site peer 2.2.2.2 tunnel 0 allow-public-networks 'disable'
set vpn ipsec site-to-site peer 2.2.2.2 tunnel 0 esp-group 'office-srv-esp'
set vpn ipsec site-to-site peer 2.2.2.2 tunnel 0 local prefix '192.168.0.0/24'
set vpn ipsec site-to-site peer 2.2.2.2 tunnel 0 remote prefix '10.0.0.0/21'
远程办公室配置
set vpn ipsec site-to-site peer 1.1.1.1 authentication mode 'pre-shared-secret'
set vpn ipsec site-to-site peer 1.1.1.1 authentication pre-shared-secret 'SomePreSharedKey'
set vpn ipsec site-to-site peer 1.1.1.1 ike-group 'office-srv-ike'
set vpn ipsec site-to-site peer 1.1.1.1 local-address '2.2.2.2'
set vpn ipsec site-to-site peer 1.1.1.1 tunnel 0 allow-nat-networks 'disable'
set vpn ipsec site-to-site peer 1.1.1.1 tunnel 0 allow-public-networks 'disable'
set vpn ipsec site-to-site peer 1.1.1.1 tunnel 0 esp-group 'office-srv-esp'
set vpn ipsec site-to-site peer 1.1.1.1 tunnel 0 local prefix '10.0.0.0/21'
set vpn ipsec site-to-site peer 1.1.1.1 tunnel 0 remote prefix '192.168.0.0/24
查看配置
vyos@srv-gw0:~$ sh vpn ike sa
Peer ID / IP                            Local ID / IP
2.2.2.2                                 1.1.1.1
   State  Encrypt  Hash    D-H Grp  NAT-T  A-Time  L-Time
   up     aes256   sha1    5        no     734     3600
vyos@srv-gw0:~$ show vpn ipsec sa
2.2.2.2                                 1.1.1.1
   Tunnel  State  Bytes Out/In   Encrypt  Hash    NAT-T  A-Time  L-Time  Proto
   0       up     7.5M/230.6K    aes256   sha1    no     567     1800    all
如果在eth1上有SNAT规则,需要添加排除规则
服务器上
set nat source rule 10 destination address '10.0.0.0/24'
set nat source rule 10 'exclude'
set nat source rule 10 outbound-interface 'eth1'
set nat source rule 10 source address '192.168.0.0/24'
远程办公室配置
set nat source rule 10 destination address '192.168.0.0/24'
set nat source rule 10 source address '10.0.0.0/24'
要允许流量传递给客户端,您需要添加以下规则
服务器配置
set firewall name OUTSIDE-LOCAL rule 32 action 'accept'
set firewall name OUTSIDE-LOCAL rule 32 source address '10.0.0.0/24'
远程配置
set firewall name OUTSIDE-LOCAL rule 32 source address '192.168.0.0/24'
34、配置DHCP server
set service dhcp-server shared-network-name 'LAN' authoritative enable
set service dhcp-server shared-network-name 'LAN' subnet '192.168.0.0/24' start '192.168.0.128' stop '192.168.0.254'
set service dhcp-server shared-network-name 'LAN' subnet '192.168.0.0/24' default-router '192.168.0.1'
set service dhcp-server shared-network-name 'LAN' subnet '192.168.0.0/24' dns-server '192.168.0.1'
set service dhcp-server shared-network-name 'LAN' subnet '192.168.0.0/24' domain-name 'internal-net'
set service dhcp-server shared-network-name 'LAN' subnet '192.168.0.0/24' lease 86400
配置静态dhcp地址
set service dhcp-server shared-network-name 'LAN' subnet '192.168.0.0/24' static-mapping 'SERVER' ip-address '192.168.0.10'
set service dhcp-server shared-network-name 'LAN' subnet '192.168.0.0/24' static-mapping 'SERVER' mac-address '00:53:00:00:00:01'
35、配置DHCP-Rely
set service dhcp‐relay interface eth0
set service dhcp-relay interface eth1
set service dhcp‐relay server 192.168.0.4
set service dhcp‐relay server 192.168.0.5
配置其他保护功能,以匹配DHCP数据包的跳数限制和最大大小
set service dhcp‐relay hop-count 10
set service dhcp‐relay max-size 576
发表于 2021-3-3 16:09:54 | 显示全部楼层
学到了.
发表于 2021-3-3 18:13:34 | 显示全部楼层
感谢楼主分享,学习了!
发表于 2021-3-5 16:54:08 | 显示全部楼层
666,赞一个。
发表于 2021-3-8 09:48:24 | 显示全部楼层
楼主这篇文章可以,感谢分享,之前有玩vyos,在网上找了很多教程,做了下测试,都是不理想,去看文档都是英文,最后我放弃了。
发表于 2021-6-28 23:48:46 | 显示全部楼层
有vyos 1.2.7的iso吗
发表于 2021-8-4 04:16:57 | 显示全部楼层
学习了。
发表于 2023-6-12 09:18:11 | 显示全部楼层
感谢楼主分享这么详细的文档,学习了!
发表于 2023-8-11 14:55:57 | 显示全部楼层
大佬,请问vyos有web后台管理吗
发表于 2024-1-8 13:31:39 | 显示全部楼层
总结的很好,可以方便的查找需要的命令用法
