楼主: yf6757176
EVE修改版1.71(开启分角色多用户,中英切换)
发表于 2018-10-12 10:55:28 | 显示全部楼层
发表于 2018-10-12 14:44:20 | 显示全部楼层
谢谢分享!
发表于 2018-10-12 16:01:16 | 显示全部楼层
11111111111111111111
发表于 2018-10-13 03:44:22 | 显示全部楼层
Can any one post on a english Site so I can add docker into? Thanks
发表于 2018-10-13 12:22:02 | 显示全部楼层
lz,在vm上装了后,dhcp不会生成ip地址,改为静态地址后,地址不能登录,网络设置都是正常的,这是怎么回事?
发表于 2018-10-13 12:30:49 | 显示全部楼层
感謝版主!
发表于 2018-10-13 15:40:44 | 显示全部楼层
发表于 2018-10-13 18:38:19 | 显示全部楼层
谢谢!!!!!!
发表于 2018-10-14 06:56:34 | 显示全部楼层
Enabled docker-ce so that items such as the Juniper container firewall (cSRX) and other containers can be used within 1.71. Try pulling a docker image that has vnc enabled or rely on html5 console. Suggest trying breakintheweb desktop xvnc image https://hub.docker.com/r/danielguerra/ubuntu-xrdp/. Use docker pull to download and then image will appear in node template under docker.io. Use html5 in eve and you get the ubuntu desktop.
https://github.com/zakhai/Eve-KKIK-docker
发表于 2018-10-14 16:56:38 | 显示全部楼层
Added to git a Dockerfile and boot script that can be used to test. It creates a new container with Openvswitch as part of it with 16 ethernet interfaces. When usin eve-ng set 16 ethernet interfaces in the eve template. I've tested this and can ping between 2 ovs switches with addresses.
